A/F gauge f'ing up..
Old Dec 31, 2004 | 06:06 PM
backagain's Avatar
backagain
Default A/F gauge f'ing up..
along with my other trouble im having with my car im having, now my aem wideband a/f gauge is going up to 17.x or so sometimes reading out full lean, if i go to redline, the gauge is not reading below 14.X . shouldn't it be reading a bit lower closer to redline ? anyone else have a similiar issue ? any way to test this other than put it on a dyno with a/f gauge ? im planning on going up to z1motorsports next week to have them take a look at the car.
Old Dec 31, 2004 | 08:31 PM
g356gear's Avatar
g356gear
Default Re: A/F gauge f'ing up..
Possible faulty o2 sensor that came with the gauge. It happened with my Greddy A/F gauge.
Old Jan 1, 2005 | 08:16 AM
backagain's Avatar
backagain
im sure they won't just send me a sensor and le me send this one back either, i'll have to take it all out, ship it, the test it, then ship me another one
Old Jan 1, 2005 | 08:51 AM
g356gear's Avatar
g356gear
The other choice is to get the car on a wideband a/f meter and a dyno and get the thing tuned....then see where you're AEM compares to a true wideband.
Old Jan 1, 2005 | 09:01 AM
G3po's Avatar
G3po
There are at least two well known causes for an early demise of wideband O2 sensors, high heat and moisture.
You can prolong sensor life by:
a) moisture: the O2 bung should be welded into the pipe pre cat / post downpipe at an angle >10degrees from horizon. This allows moisture to drain away from the sensor when cold.
b) heat : use a heat sink such as one sold by :
http://www.innovatemotorsports.com/x...me.php?cat=250
Note: if you run test pipes , moveing the bung back further away from the downpipe offer similar benefit as the thermal isolator above.
Old Jan 1, 2005 | 03:05 PM
westpak's Avatar
westpak
SFZCC
I agree before assuming it is the wideband get that thing to a dyno and check it out to make sure it is not the tune.
Old Jan 1, 2005 | 05:03 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
if you are using the AEM widband, mine broke too. AEM says they are defective, and wants me to send back the entire unit for a replacement/fix. Mine last 8000miles before it broke.
Old Jan 1, 2005 | 05:56 PM
backagain's Avatar
backagain
i have less than 1000 miles , i am going to HATE to have to take that thing out and ship it back to them.
Old Jan 1, 2005 | 10:59 PM
fernandito7's Avatar
fernandito7
Mine is bad as well. I have like 4000 miles on it. I have to send it baack to aem as well. ITs gonna be a b!tch to take it out and then put it back in. They want the whole unit inlcuidng the o2 sensor.
Depravity
Oct 1, 2015 04:49 PM
FromGtoZ
Sep 20, 2015 03:41 PM
