Turbo Kit on a A/T & tiptronic Z
Old Jan 20, 2005 | 02:58 AM
yorky500's Avatar
yorky500
Default Turbo Kit on a A/T & tiptronic Z
I am a bit of numpty when it comes to engines, but I was wondering if I can add a turbo kit (say APS) to my car even though it has an Automatic and tiptronic grearbox?
It may be a bit of a stupiod question, but i have to ask.
Thanks guys.
Old Jan 20, 2005 | 03:30 PM
Aggro_Al's Avatar
Aggro_Al
Default Re: Turbo Kit on a A/T & tiptronic Z
Thanks guys.
Yes, you can add turbos to the 5AT. Make sure the manufacturer designed it to fit in the engine bay with the 350Z 5AT. Adding turbos on the 5AT is great because the torque converter will allow you to launch in boost. Not only do you eliminate lag, you can actually pre-load the turbos and spool them before you launch. You'll need a high-stall TC to do this effectively.
Old Jan 20, 2005 | 10:08 PM
yorky500's Avatar
yorky500
Aggro_al,
Cheers squire,
u have just made my morning. Glad to know I bought a car with AT that I can add a turbo, at some time in the future!
Old Jan 21, 2005 | 08:43 AM
hypeiv's Avatar
hypeiv
not 100% sure but I think if you get a turbo(s) or a super you need to use the tiptronic when your going WOT but I think its ok to go full auto for track and daily driving... but I really don't know for sure.
Old Jan 21, 2005 | 12:21 PM
JoneZZZ's Avatar
JoneZZZ
Until you get the 5AT shift points firmed up(valve body upgraded), you may run the risk of bouncing off the rev limiter at WOT while in auto.....
Old Jan 21, 2005 | 01:42 PM
johanna1's Avatar
johanna1
Mainly all you need to do is get the valve body and tq converter done. A nice place to get this done at would be SGP Racing. They have already done one on a Z and said it worked out great. They also sell tq converters there. I was thinking Level Ten but have changed my mine to try someone else for a change. With manual or auto, going turbo you will need to stiffen up the tranny to handle the hp so it does not do damage or make it slip. I think if you get the valve body done you will not need to worry about it going over the redline. Also the reflash helps out. Manual mode through is the best way to race it through.
Old Jan 21, 2005 | 01:44 PM
Sins4u33's Avatar
Sins4u33
the car is not intended to be driving in automatic mode when a F/I application is added....the D (drive) mode wont shift in time, that why u must shift with the tektronic mode, or manual mode whatever you want to call it. There is much more control of the car in manual mode i beleive. automatic (drive mode) the car doesn't stop moving...and brakes are more dependant, when u could just downshift with the manual mode.
Ben Yavari
AAM
Old Jan 21, 2005 | 01:49 PM
johanna1's Avatar
johanna1
What's up Ben. I knew I were see you here. This is are type of tread. I talked with a couple people and they said once you get the vb done that it can run perfectly in auto mode. Also, they said that the reflash helped them out to. Has altered had any experience with the reflash helping them shift in auto mode? I know a couple of auto people with F/I on this forum without the vb done said the reflash helped them out where they can now run in auto mode.
Old Jan 22, 2005 | 12:21 AM
yorky500's Avatar
yorky500
Thanks for the replies, trouble is though I am not in the States, but in the Desert sands of Dubai in the UAE, so not sure where i can get this done!
perhaps try Nissan dealership? can they be trusted?
Old Jan 22, 2005 | 10:19 PM
Aggro_Al's Avatar
Aggro_Al
You can order valve body, tranny cooler and torque converter upgrades online if necessary. If you can be without your car for a few days you can send your ECU to get flashed by removing it and sending to a company that does that sort of thing. They will send back the ECU and you just re-install it. Most good mechanics can do a torque converter or valvebody job in just a few hours and it is not that expensive when compared to other mods. Removing and installing the ECU is a do-it-yourself job. It's not that difficult.
Old Jan 23, 2005 | 12:39 AM
yorky500's Avatar
yorky500
Thanks Aggro_Al,
Anything to do with engines is not a do-it-uself job when it comes to me! hahahahahahahahaha.
I am dead scared of touching engines. Everything else is OK ish, but engines! Let me see what I can source around here.
Old Jan 23, 2005 | 07:13 AM
blackend's Avatar
blackend
there is one shop in ABUDHABI they install gt twin turbo for my car which is AT and it will cost you around 30000 DHS
Old Jan 23, 2005 | 08:44 AM
yorky500's Avatar
yorky500
Ouch, hell fire and brimstone, thats like US$9000.00
May have to think again!
Old Jan 23, 2005 | 09:08 AM
hypeiv's Avatar
hypeiv
yea most people forget about the install and tune pricing. A friend of mine has his heart set on a g35c and a vortec... he figured ~30k for a used g35c and 5k for the super. I seriously hope he doesn't buy it even if he is willing to pay the 3 to 4k for the install and tune b/c if anything goes wrong he really can't afford to get it fixed.
Old Jan 23, 2005 | 09:37 AM
johanna1's Avatar
johanna1
Vortech does not cost that much to install if you get the right person. Just to install it at most shops will run you around $700-1200. Its not as nearly as hard as a twin turbo. You can get a car tuned pretty cheap too and right if you also find the right shop. Some shops don't know how to tune very well and they over charge. Their are acouple places around here that do that. I know from experience. One shop claimed they were so good and other people recommended them to at first until I blew a spark plug on my turbo civic. I don't know if I was running lean or rich but the spark plug blew cause of dentnation and blew in half.
Old Feb 14, 2005 | 09:56 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Moved.
Old Feb 15, 2005 | 05:05 AM
KShep's Avatar
KShep
On the street I have had zero problems shifting in either mode. No experience on the track to report.
This thread may provide some additional info.
https://my350z.com/forum/showthread....ight=Whosdaddy
Old Feb 15, 2005 | 06:49 AM
wfcall's Avatar
wfcall
my female friends auto 350z has ati procharger and level ten valve body upgrade along with alot of other performance bolt-ons and I can definetly tell you that the level ten upgrade did not correct the "bumping the rev-limiter" problem when driven in auto.
What is worse is that level ten said they were completly aware of this issue and that it WOULD fix it.
After I installed the Valve body and complained NOW they tell me that they reccommend a reflash to raise the rev-limiter
The shift command cannot be adjusted as far as RPM's go
The command comes close enough to Redline that the horsepower induced slip 'causes the transmission to take just a little too long to complete the shift and therefore it hits the rev-limiter.
Shifting in manual mode sucks because the time between your input and when the TCM initiates a shift makes it neccessary to shift at around 5600 in order to have any hopes of staying out of the rev-limiter.
This is a horrible way to drag race; ruins consistency.
Old Feb 15, 2005 | 06:54 AM
wfcall's Avatar
wfcall
SGP sends thier Valve Bodies out to someone else. don't know who 'cause I did not ask who but Kyle admitted that they do.
Level Ten
Stillen
Only one I can find that do this tranny.
EnjukuRacing
Sep 30, 2015 06:55 AM
