500rwhp 11psi stock motor
Old Jan 26, 2005 | 09:13 PM
zero2prove's Avatar
zero2prove
Default 500rwhp 11psi stock motor
Stock motor
APS TT kit
APS Cat deletes
APS Dual Exhaust
11psi of boost
93 octane
some tuning
For those that don't view the other Z forums.
Old Jan 26, 2005 | 09:14 PM
narkotic's Avatar
narkotic
Default Re: 500rwhp 11psi stock motor
good lord.
Originally posted by zero2prove
Stock motor
APS TT kit
APS Cat deletes
APS Dual Exhaust
11psi of boost
93 octane
some tuning
350zDCalb's Avatar
350zDCalb
builtZmotors
500rwhp 11psi stock motor = eventual swiss cheese block
Old Jan 26, 2005 | 09:27 PM
phunk's Avatar
phunk
CJ Motorsports
Good work Tuan... I knew you would do it.
Just goes to show how easy APS has made the life of the 350z tuner!
350zDCalb: With the MAP based tuning, elimination of potentially scattered CAS signal, and professional installation... I do not believe this to be any hazard on the motor. Since putting so much abuse on my own car at the power levels it was at and seeing the engine internals hold up just fine... I would have the confidence just as well to push it so hard.
He and many more to come will show that this engine can take a lot more... and I am willing to bet you will see 600rwhp on a stock engine.
-Charles
Old Jan 26, 2005 | 09:36 PM
zero2prove's Avatar
zero2prove
Phunk,
I have to agree with you and surely someday someone else will make more power with correct supporting mods. Its just a matter of time and effort. While I don't want to make any assumptions until more APS kits are out there with some high mileage on them, I'll bet you'll see less blown up motors with APS kits than most other TT kits.
The Z seems to pull pretty smoothly on the dyno. One of my head techs even notice as I did a pull.
I'll try to put some abuse on this setup as long as can, just to see how she holds up. It just plainly sucks that we have to deal with the cold chicago winter and no traction.
Tuan
Old Jan 26, 2005 | 10:30 PM
thawk408's Avatar
thawk408
Stock motor
APS TT kit
APS Cat deletes
APS Dual Exhaust
11psi of boost
93 octane
some tuning
Absolutely AWESOME!!
Old Jan 26, 2005 | 10:54 PM
JisNis's Avatar
JisNis
APS seems like the way to go to obtain high and safe hp levels. You guys think they will ever go down on the price? The price is just to much.
Old Jan 26, 2005 | 11:12 PM
thawk408's Avatar
thawk408
Quality cost! It would be nice if they went down in price, but the kit seems worth the extra money.
Old Jan 27, 2005 | 05:57 AM
jpc350z's Avatar
jpc350z
Stock motor
APS TT kit
APS Cat deletes
APS Dual Exhaust
11psi of boost
93 octane
some tuning
Very impressive #'s. Curious as to why the Tq and Hp curves don't intersect at 5252 RPM..
Old Jan 27, 2005 | 06:47 AM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Default Re: Re: 500rwhp 11psi stock motor
500 on a stock block is an incredible feat but dont expect it to last long and I will put money on that.It is not about tuning, it is about the amount of stress, 500 horsepower will put on the stock internals.The rods and pistons in the VQ are really not up to the task and I have seen the piles of blown motors at Mossy to confirm my beliefs.Good luck though.
Old Jan 27, 2005 | 06:56 AM
leemik's Avatar
leemik
look at the scale on each side.. they are not equal..
--mike
Old Jan 27, 2005 | 07:26 AM
jpc350z's Avatar
jpc350z
Default Re: Re: Re: 500rwhp 11psi stock motor
--mike
Regardless of scale they both have to be equal where they cross and they don't..Hp=Tq at 5252RPM..What am I missing. Thanks
Old Jan 27, 2005 | 07:40 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Default Re: Re: Re: Re: 500rwhp 11psi stock motor
Sometimes if the dyno isn't calibrated right it won't graph properly. So these hp numbers could be off.
Old Jan 27, 2005 | 07:57 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Tuan, when the weather clears, I'm sure people would be interested in seeing this car on Charles's dynojet. As many have discussed before, the only way to compare different cars to different cars, is to run them on an inertial based dyno (DYnojet). Load based dynos are incredible for tuning....as you have shown...not not so good for comparing one car to another.....on different dynos and different parts of the country.
Any plans for that?
Old Jan 27, 2005 | 08:34 AM
Monsta's Avatar
Monsta
Stock engine or not, you achieved it. Good Job.
Old Jan 27, 2005 | 08:44 AM
calimarc's Avatar
calimarc
Tuan didn't elaborate in this post, but he did on another forum where this thread began. I believe he made it CLEAR that he was looking for the limits of a stock VQ engine. Of course he was already planning on building up the engine, so in the event that he did blow the motor then he was prepared for that.
And I do believe it's about TUNING. I'd be willing to bet that the pile of blown motors at Mossy was from turbo kits that came incomplete out of the box. These kits claimed to be safe and "complete" out of the box but who really believes that now? Everyone who was fortunate enough to not run into trouble with those kits began to look for solutions to address timing and boost spikes. Last but not least...almost everyone who has F.I. on this forum is taking heed to protect against a crank / cam angle sensor issue that effects some of our cars.
I think everyone understands that our engines have limits. However I don't think you can ever overstate the importance of good tuning.
Old Jan 27, 2005 | 08:54 AM
zero2prove's Avatar
zero2prove
Default Re: Re: Re: Re: Re: 500rwhp 11psi stock motor
Torque is what is actually measured on the Dynapack while HP power are SAE corrected. Plus the scale on torque and HP are different on each side.
Old Jan 27, 2005 | 09:00 AM
ZippyCar's Avatar
ZippyCar
Way to go Tuan. I can't wait to see the "next level" once you have built you engine up!
Cheers!
Old Jan 27, 2005 | 09:12 AM
Steve@Evolution's Avatar
Steve@Evolution
Hp and Tq cross at 5252rpm only applies to graphs that have equal scale of HP and TQ. It how the tuner set up his graph, the # are still correct.
Old Jan 27, 2005 | 09:39 AM
jpc350z's Avatar
jpc350z
Understand the difference in scales.. However, wherever they cross don't they have to be equal? (Hp must = Tq at that point) If not why not? If they have to be equal and they are not then the scale absolute values are suspect.. Thanks
