View Poll Results: What is your favorite kit?
Air Power Systems (APS) Single Turbocharger Kit
17.39%
Eternal Motorsports Single Turbocharger Kit
0%
NCR Performance Single Turbocharger Kit
0%
Squire Turbo Systems (STS) Single Turbocharger Kit
0%
Turbonetics Single Turbocharger Kit
30.43%
Velocity [Performance/Motorsports] Single Turbocharger Kit
0%
Air Power Systems (APS) Twin Turbocharger Kit
20.29%
GReddy Twin Turbocharger Kit
18.84%
Jim Wolf Technology (JWT) Twin Turbocharger Kit
8.70%
Jotech Motorsports Twin Turbocharger Kit
0%
Nizpro Twin Turbocharger Kit
0%
SSR-Engineering/Speed Force Racing Twin Turbocharger Kit
4.35%
Ultimate Racing Twin Turbocharger Kit
0%
Voters: 69. You may not vote on this poll
Turbocharger FAQ - Come in and add some info! Updated: 6/23/05
Old Feb 19, 2005 | 09:18 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Post Turbocharger FAQ - Come in and add some info! Updated: 6/23/05
Temp. removed.
Old Feb 19, 2005 | 10:12 AM
Brandon@Forged
Post
Temp. removed.
Originally Posted by s12driver
Not sure where to post this. I got bored and overlayed some of the dyno data. It's interesting to see.
Old Feb 19, 2005 | 10:16 AM
Brandon@Forged
Single Turbocharger Kits
Squire Turbocharger Systems (STS) Single Turbocharger Kit (R&D)
Velocity [Motorsports/Performance] Single Turbocharger Kit
Twin Turbochargers Kits
Power Enterprise Twin Turbocharger Kit
Old Feb 19, 2005 | 10:18 AM
Brandon@Forged
Post Air Power Systems (APS) Single Turbocharger Kit
(1) Garrett GT3582R Dual-Ball-Bearing Water-Cooled Turbocharger
Note: Image above taken without lower impact shield
APS Intercooled Single Turbo High Output SystemThere's little doubt that the Nissan 350Z is a wonderful and exciting car to drive - though when enhanced with an APS intercooled turbo system, it's straight to the supercar club.
APS recognises that some 350Z performance enthusiasts demand alternatives to low cost centrifugal superchargers for the Z but are reluctant to move to the price bracket of twin turbocharged systems. The perfect solution is the APS Intercooled Single Turbo system. With huge outright horsepower and significantly higher torque in the low to mid engine RPM range than centrifugal superchargers, the APS Intercooled Single Turbo system delivers far greater engine performance at a comparable price point.
Utilizing the latest in water cooled twin ball bearing Garrett turbocharger technology - mounted low and mean in the 350Z, APS ensures that the greatest amount of exhaust gas energy is available to the turbocharger for crisp turbocharger response and high power and torque. This solves the turbocharger lag problems associated with systems that situate the turbocharger inside the Z's engine bay. In addition, high engine bay temperatures (which is of great concern in high performance vehicles) are alleviated by the APS turbo system design.
Testament to the turbocharger specification and tubing configuration is the absolutely outstanding boost response of the APS Intercooled Single Turbo System. With positive manifold pressure just above idle speed and full steady state turbocharger boost pressure by 2,500 RPM, the APS system makes for an awesome drive with strong low and mid RPM torque - and of course wild top end horsepower. After all, nobody likes to wait.
Drawing on the technology utilized in the APS Intercooled Twin Turbo system, APS has designed and manufactured a custom configured, vertical flow high efficiency intercooler utilizing custom designed light weight cast aluminium end tanks. Extremely high flow rates and massive temperature reduction - a level of performance that other manufacturers can only aspire to achieve.
With a huge 25” x 9” x 3.5” core, at 650 hp flywheel, the pressure drop is less than 1.0 psi. At the same turbocharger flow conditions, the intercooler outlet temperature is less than 15°F higher than ambient, at any vehicle speed over 50mph. Truly outstanding results at such a huge horsepower level. So just like the APS turbochargers, the APS intercooler has massive additional headroom available.
Vertical flow inside the APS intercooler is by far the optimum configuration given the space considerations that must be accounted for in the front of the vehicle. This solves the huge air flow restriction problems that horizontal flow cores experience particularly at high power levels.s 90 degrees twice on entry and again twice on exit. In addition, both turns must take place inside the height of the end tank.
Importantly, the APS intercooler uses the latest in Bar and Plate core technology, not low cost off the shelf tube and fin. Other than the fact that the APS intercooler core boasts the highest flow and greatest temperature reduction, the bar and plate construction results in an inherently strong intercooler core of high thermal inertia. The advantage here for the performance street car and drag race enthusiast is that with the core's high thermal inertia, massive reserves of cooling capacity are available in situations where ambient air flow over the core is low. So, after a power run to heat tyres prior to staging for a quarter mile pass, there is plenty of intercooler capacity to launch with full power at your disposal - rather than forsaking power with a tube and fin construction core that becomes heat soaked during the initial burst.
Unlike other systems that require cutting or removal of structural components at the front of the vehicle, APS has designed the 350Z FMIC as a truly bolt-on unit that not only maintains the structural integrity of the vehicle, but also delivers outstanding intercooler performance.
Best of all, the APS Intercooled Single Turbo system comes complete with a comprehensive full return, constant differential fuel system and large drop in injectors, high volume externally finned oil pan that employs extensive internal baffles right through to the awesome APS dual vent blow off valve.
The APS Intercooled Single Turbo system for the 350Z is by far the most extensively engineered, complete and comprehensive single turbo system on the market. Right from the latest technology water cooled dual ball bearing turbocharger and huge vertical flow bar and plate intercooler, through to the APS High Volume oil pan, innovative exhaust tubing, full return constant differential pressure fuel system and APS dual vent blow off valve - The ultimate single turbocharger system for the Nissan 350Z
NOTE Auto Transmission Applicability Reference
  1. Physically fits
  2. Requires torque capacity upgrade by trans specialist
Video:
(replace the "***************" with airpowersystems
http://www.*************/aps_single.wmv
Old Feb 19, 2005 | 10:25 AM
Brandon@Forged
Post Eternal Motorsports Single Turbocharger Kit
Still in R&D. Information not available yet.
Old Feb 19, 2005 | 10:30 AM
Brandon@Forged
Post NCR Performance Single Turbocharger Kit
Old Feb 19, 2005 | 10:32 AM
Brandon@Forged
Post Squire Turbo Systems (STS) Single Turbocharger Kit
Old Feb 19, 2005 | 10:35 AM
Brandon@Forged
Post Turbonetics Single Turbocharger Kit
Originally Posted by phatmitzu
Installation instruction with more detailed pictures and parts list for the Turbonetics Single Turbo.
http://members.***.net/turbonetics35...icsinstman.pdf
Originally Posted by MIAPLAYA
I have newer pics of the Turbonetics kit at http://members.***.net/turbonetics350z
and the install instructions are at http://members.***.net/turbonetics35...icsinstman.pdf
Turbonetics Single Turbo kit:
Turbonetics 60-1 Stage V ceramic ball bearing turbo
Spearco Front Mount Intercooler
Turbonetics Evolution external wastegate
Turbonetics Raptor Blow off valve
380 CC drop in/plug in injectors
Walbro 255 lph fuel pump
Modified stock FPR
Turbonetics custom tuned ECU flash
All stainless steel polished mandrel bent exhaust piping
All aluminum mandrel bent powder coated black chrome intake piping
All piping utilizes v band clamps
A case of Turbonetics synthetic TS-1 oil
12 month/12,000 mile no fault no hassle warranty on EVERY part of the kit
Power output of 386 RWHP at 8 PSI.
AFR of 11.5:1 from boost to redline
MSRP: $5,570
Vendor Price: $4750
Second version is all of the above plus a High Flow cat on the turbo downpipe
Third version: (Tuner version)
Turbonetics Raptor Blow Off Valve
Spearco front Mount intercooler
Pictures available at http://members.***.net/w.suarez/z.htm
http://www.imagestation.com/album/?id=2454005093
Username: SEMA2004 Password: 123456
Notes: Turbo included with the kit is good to about 650 RWHP at roughly 18-20 PSI.
Fuel system included with the kit good to AT LEAST 500 RWHP with proper tuning.
No issues as of yet have been reported.
Ability to run aftermarket headers as long as the outlet flange is in the stock location.
Must use either a y pipe back exhaust (Apexi, Tanabe, Fujitsobo, etc) or a modified dual.
Upgraded compressor wheel or turbo available through Turbonetics as part of the kit at an added cost. Turbonetics would need to know your output plans to customize it to your needs.
G35 version of the kit in production by March 28.
Question and answers:
Originally posted by whitehatmatt
This is probably a dumb question, but I'm new to this. Do you need to change out rods and pistons and that type of stuff on the engine to run this type of setup?
Thanks,
Read my first and second post. For the stock boost level...no.
--Nis350ZTT
And videos... Pt 1: http://www.imagestation.com/video/p...l?id=4143609603
Pt2: http://www.imagestation.com/video/p...l?id=4143608244
Pt3: http://www.imagestation.com/video/p...l?id=4143607578
Old Feb 19, 2005 | 12:41 PM
Brandon@Forged
Post Velocity [Performance/Motorsports] Single Turbocharger Kit
The G35 put down 343 hp and 350 torque on 7 psi, boost starting around 2000 rpms and full boost around 3500 rpms.
Video of the kit: http://rapidshare.de/files/1841117/ST_vid.wmv.html
Price: $7,500 installed and tuned.
The turbo is a Precision SC61 (rated at 630 HP), the intercooler is a Precision large intercooler, Tial blow off valve and a Tial wastegate. All of the piping is stainless steel. All of it, even the intake. K&N airfilter. All of the best parts were used on this kit: no internal wastegates, no cheap blow off valves, no cheap piping. if anyone doesn't know Precision Engineering, their turbos are Garrett turbos with their own A/R design that makes the turbo boost quicker than a regular Garrett.
Old Feb 21, 2005 | 10:06 PM
Brandon@Forged
Post Air Power Systems (APS) Twin Turbocharger Kit
(2) Garrett GT3528R Dual-Ball-Bearing Water-Cooled Turbocharger (custom made by Air Power Systems (APS))
(1) Air Power Systems (APS) Front Mount Intercooler (Bar and plate)
Nissan 350ZSince the first release of 'the Z' in the early 70's, Nissan ignited the passion of performance enthusiasts who desired high performance, sharp handling and killer looks. The 350Z has now taken the Z legend to new heights and has produced what is arguably the greatest Z yet.
Now, the perfect partnership has been formed in order to take the 350Z to a performance level that will have thoroughbred supercars running scared. Drawing on over 20 years of turbocharging, supercharging, intercooling and engine management system design and production knowledge, APS has created the ultimate High Output System for the Z's 3.5L engine.
With insane horsepower and monster torque, the APS High Output System moves the 350Z performance enthusiast exclusively into the supercar owner's club.
Best of all, the APS enhanced 350Z delivers uncompromised driveability. Crisp throttle response, tidal waves of torque, silky smooth highway cruising and excellent fuel economy all add up to an outstanding daily driver - and at your whim, mash the pedal and unleash the beast within.
  1. Physically fits
APS Intercooled TWIN Turbo System
The APS Intercooled Twin Turbo System includes the following major product groups.
P/N APS350Z-TTS/01
APS Intercooled Twin Turbo System major product groups
TurbochargersIntercoolerTwin, state of the art, extreme efficiency, super compact, Garrett twin ball bearing turbochargers with a custom APS aerodynamic configuration Click here for information
Massive APS DR Series Bar & Plate Front Mount Intercooler with unique cast alloy end tanks Click here for information
DuctingExhaust ManifoldsPolished Stainless Steel and TIG welded intake and turbocharger discharge ducting Click here for information
High Energy cast ductile iron and precision machined exhaust manifolds and turbine outlet housings. Click here for information
Engine ManagementFuel SystemAPS custom mapped Plug-In engine management computer for optimum engine tune/power Click here for information
APS High Output Injectors with upgraded fuel supply. Includes a plug-in replacement loom - no cutting and soldering! Click here for information
Air IntakesOil PanTwin High Flow Cold Air Intake System Click here for information
Huge cast alloy high capacity engine oil pan with oil return ports Click here for information
P/N APS350Z-HVO/01
APS Blow Off ValveAPS High Volume Twin Vent Blow Off Valve Click here for information
Old Feb 25, 2005 | 07:26 AM
Brandon@Forged
Post GReddy Twin Turbocharger Kit
How much does this kit cost?
You can find it anywhere from $5,400 with GReddy front-mount intercooler to $6,800 with GReddy front-mount intercooler.
What does this kit contain?
Two turbochargers, one front mount intercooler, six fuel injectors, all neccessary tubing and accessories, two wastegates, two intake filters, exhaust manifolds, and engine management.
How much does it cost to install it?
Expect to pay anywhere from $1,800 to $3,000.
What turbochargers do this kit contain?
Two Mitsubishi TD05H-18G Turbochargers
Does this kit include a fuel solution?
For the stock pounds per square inch (PSI) level?, yes.
Does this kit have some kind of cooling?
GReddy offers a front mount intercooler to cool the air coming into the engine from the turbochargers, most believe it is pretty much necessary.
What is the stock boost level for this kit?
5.6 Pounds per Square Inch (PSI) of boost.
What kind of power should I expect on the stock boost level?
About 360 rear wheel horsepower.
Specifications
Two Mitsubishi TD05-18G Turbochargers
Two GReddy Tial External Wastegates
Two GReddy Airinx AY SM Air Filters
Dual Cast Iron Manifolds & Elbows
Aluminum Intake Pipes
Pre-Programed GReddy E-MANAGE
(6) 440cc Injectors
All Silicon Hoses and Connectors
Welded Oil Pans for Oil Return
All Hardware and Gaskets
Preset boost level: 5.6psi
Estimated base whp: 330-360whp
Issues with the Greddy kit that should be addresses:
Problem: No timing solution included
Solution: Buy eManage ignition timing harness and 6 diodes to protect the coils.
Problem: Stock fuel system only good for 6-7psi before you start to go lean due to rapidly dropping fuel pressure.
Solution: Walbros 255 drop in replacement pump, and a return fuel system with FPR plug, siphon correction kit, and new raising rate FPR. CJ-Motorsports and Altered Atmosphere make very high quality compelete return fuel systems that are easily good for 700whp with properly sized injectors.
Problem: Too much back pressure with stock restrictive cats
Solution: Install test-pipes. Brings the turbos to life!
Problem: Scattered ignition timing due to eratic crank angle sensor. May contribute to catestrophic engine failure
Solution: Replace stock CAS wire with a new shielded wire. CJ Motorsports sells this for $75. GB is currently running as well
Brandon@Forged
Post Jim Wolf Technology (JWT) Twin Turbocharger Kit
(2) Jim Wolf Technology 530 Ball-Bearing Turbocharger
350Z TWIN TURBO KIT UPDATE
Date:3/18/2005
The G35 TT kits are finished and awaiting final CARB certification. While this has been almost a full year of work, it will be the only street legal turbo kit for the G35 and 350Z available. The good news is that the 350Z version has been completed and in dyno testing mode at this time. Below is the 350Z engine layout. Both kits will be ready to ship once the certification process is complete. Note the intercoolers on the 350Z below. A completely integral center casting was designed to achieve a near perfect flow to the throttle tube, while using the maximum frontal area of the stock body nose. No stock parts including bumper bar or air bag sensors are moved or modified! Also note that all of the fluid bottles retain the stock locations.
Below is the first dyno session above the 6.8psi production boost, which shows off the incredible drivability of the kit. This is a kit that is specifically designed to put all of the power exactly were it can be used! Note the amazing mean hp of 310.9, this is the most important HP number for comparison as it represents the total area under the curve for the run. A somewhat useless "Brag Number" just before the rev cut, will never make you smile as much as a high mean overall HP and torque value. Keep in mind that this is still with all of the catalytic converters in place! We will let you know when the emission testing is finished.
Old Mar 3, 2005 | 12:37 AM
Brandon@Forged
Post Jotech Motorsports Twin Turbocharger Kit
(2) Garrett GT28 Ball-Bearing Water-Cooled Turbocharger
(1) Precision Engineering Front Mount Intercooler
(2) Tial 38mm External Wastegates
(2) HKS Air Filters
Jotech Intercooler Piping
Tial Blow-Off Valve
Brandon@Forged
Post Nizpro Twin Turbocharger Kit
Brandon@Forged
Post Power Enterprise Twin Turbocharger Kit
(2) (Power Enterprise Specification) IHI 1420 Ball-Bearing Turbocharger
(1) Front-Mount Intercooler
The world renowned Power Enterprise releases the Z33 Twin Turbo Kit. Powerful,race car like torque throughout high rpm range makes your Z33 more fun to drive. The Power Enterprise Z33 complete bolt-on turbo kit includes front mount intercooler and fuel upgrades. Complete bolt-on twin turbo kit for Fairlady Z33 has a capacity for achieving 500ps+.You will enjoy every step of tuning with this kit.
     ①Z33 Twin Turbo Kit (Full Kit)
 $8480.00
②Z33 Twin Turbo Kit (Without Intercooler and High Capacity Oil Pan)
 $6480.00
③Z33 Twin Turbo Kit (Without Intercooler ,High Capacity Oil Pan, Injectors,Fuel System)
 $5480,00
   ■ Kit Contents
 ・PE1420×2
 ・Custom exhaust manifold
  ×2
 ・Custom outlet pipe ×2
 ・Custom high capacity
  fuel pump
  aluminum oil pan
 (Adds 1 litre of capacity)
 ・Power's high capacity fuel
  injectors (6)
 ・Fuel pressure regulator
 ・Air Impulse II (2)
 ・Custom mount air-to-air
  intercooler
 ・Inlet and compression
  pipe set
 ・Oil line set
 ・Gaskets
350PS/5800rpm
Output
420PS/5800rpm
40kgm/4200rpm
Torque
56kgm/4200rpm
0.3kg/c㎡
Boost
0.5kg/c㎡
※ Data by Dyno testing Z33 TWIN TURBO CHARGER KIT
NOW ON SALE
 MSRP: $8480
   ②Z33 Twin Turbo Kit (Without the Intercooler and High Capacity oil pan)  ■ Kit Contents
 ・PE1420×2
  ×2
  fuel pump
 ・Gaskets
  injectors (6)
 ・Air Impulse II (2)
 ・Oil line set
  pipe set
NOW ON SALE
MSRP: $6480
③Z33 Twin Turbo Kit (Without Intercooler, High Capacity oil pan, Injectors, Fuel System)
     ■ Kit Contents:
 ・PE1420×2
  ×2
 ・Custom outlet pipe×2
 ・Air Impulse II (2)
 ・Oil line set
  pipe set
NOW ON SALE
MSRP: $5480
  Seperative Type Actuator Included PE1420 Standard Equipment
With our seperative actuator you can modify the actuator to your specific needs. You can select a different spring to use in the actuator acheiving desired boost levels. We have many different springs are available for your tuning needs.
Old Mar 3, 2005 | 12:38 AM
Brandon@Forged
Post SSR-Engineering/Speed Force Racing Twin Turbocharger Kit
Two Turbonetics T-3 Turbochargers
Two Tial 38mm wastegates, external, can be vented to atmosphere or routed into the exhaust
Two 321 Stainless-Steel Equal-Length headers
Two 304 Stainless-Steel Downpipes
One Spearco Intercooler for the 350Z, Two for the G35
HKS SSQV BOV (Super Sequential) (Blow-Off Valve)
Two K&N Air Filters
"The Speed Force Racing twin turbo system for the G35/350Z includes the following parts: two T-3 turbos,turbochrger mounting brackets,oil feed and return lines,321SS headers with slip-fit merge collectors,two 38mm Tial wastegates,two 304SS downpipes,Spearco intercooler(the G35 gets two),Mocal scavenge pump,aluminum oil sump,hoses and fittings,aluminum intake and intercooler piping,silicone hoses,stainless steel hose clamps, HKS Sequential blow-off valve,two K&N airfilters,Split Second engine management system (which comes pre-tuned) and all hardware and instructions needed for a professional install."
They also offer two more options:
Ball-bearing turbo option-$1000
Polishing/Powder Coating option-$495
Videos:
http://www.speedforceracing.com/videos/g35tt.AVI
http://www.speedforceracing.com/videos/MVI_3449.AVI
http://www.speedforceracing.com/videos/350ztt.AVI (built motor, 8.5 CR, 510hp)
Brandon@Forged
Post Ultimate Racing Twin Turbocharger Kit
Kit Components:
- Twin Custom Garrett T3/T04E Turbochargers (800HP capable)
- Twin Heavy Gauge Tubular Exhaust Manifolds
- Twin TiAL 38mm External Wastegates
- Twin Stainless Steel Wastegate Dump Pipes*
- Twin Stainless Steel Intake Pipes with K&N Air Filters
- Twin Stainless Steel Downpipes**
- Large Bar and Plate Front Mount Intercooler
- Polished Stainless Steel Intercooler Piping
- HKS SSQV Blow-Off Valve
- 630cc Fast Reacting Fuel Injectors
- Custom Intank Fuel Pump with complete Fuel Return System
- Coolant Overflow Tank
- All Lines, Fittings, Clamps, Hoses, etc
* Available with open atmosphere dump or recirculated back into downpipe
** Available Cat-less Or with High-Flow Cats
PRICE: TBA
350Z Twin Turbo Kit @ 8.5psi tuned with HKS F-CON V Pro
466.27 WHP - 463.72 FT.LBS
Old Jun 18, 2005 | 11:54 PM
Brandon@Forged
Thumbs up Gotta give credit where credit is due:
Credit to:
Me
Enron Exec
gq_626
westpak
bruschijr
miaplaya
cquence 350 [Z]
350zdcalb
going deep
nitrous350
gurgenpb
t32gzz
mazzoo
narkotic
whitehatmatt
s12driver
phatmitzu
I extremely appreciate the help! Thank you!
Old Jun 18, 2005 | 11:55 PM
Brandon@Forged
Exclamation Instructions:
The way this will work is:
You post your information. I will take your information and add it to the list and give you credit, and then delete your post.
PLEASE FOLLOW THESE RULES CORRECTLY!!!
Old Jun 23, 2005 | 02:26 PM
Brandon@Forged
Still updating.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
