Who's running Vortech, cam , return fuel, bigger injector
Old Feb 27, 2005 | 04:05 PM
booger's Avatar
booger
Default Who's running Vortech, cam , return fuel, bigger injector
Wondering if any one else is running all of them together ? Having trouble with partial throttle under boost . When at partial throttle under vacuum...I can give it a little more gas and Im in boost . Cant get the A/F down . If any one is running cams , return fuel system, and bigger injetors , and have it tuned . I would love to see a shot of your R4 fuel map from -2 vacuum to as much boost as you can get in the pic...thanks...Bill
Old Feb 28, 2005 | 05:08 AM
aron's Avatar
aron
I'll be getting the PE 510cc larger injectors and the AAM spec return fuel system installed in about 2-3 months if all goes as planned. I'll update when all is done.
Old Feb 28, 2005 | 05:38 AM
booger's Avatar
booger
LouZer is going to install in a week or two also . The 3 of us can figure it out . Im thinking its more of a BOV adjustment than any thing . With the BOV adjusted the way we had it before cams . It was closing at -4 to -6in of vacuum . That setting now is to soon . Its the cams..Im only making -6 in of vacuum at idle and in park . -4.5in in drive and at idle . I got a couple of things Im going to try bessides the BOV adjustment also . I'll post if I figure anything out
