Turbo vs Supercharger
Old Nov 15, 2002 | 01:00 PM
jreiter's Avatar
jreiter
Originally posted by Diskus
Anybody know if there is even enough room for a twin turbo?? Who would make a twin turbo?
Seems like a twin turbo is the only reasonable bet on a V engine, so hopefully there is room! Does anyone here know if a single turbo config has ever been done on a V engine? (V6, V8, etc.) Seems like it would be a *huge* pain in the rear to do a single on a V.
Typically you hang a turbo straight off the exhaust manifold. On a V engine, since there are two exhaust manifolds (one on each side of the engine) it seems like mounting a turbo on each manifold would be much easier than trying to do a single turbo and having to run exhaust pipes from each manifold up into one turbo. Ugh.
On that note, every factory turbocharged V engine I can think of uses twin turbos... one on each manifold. (Audi S4, RS4, RS6, R8 racecar, Porsche 959, Ferrari F40?... probably tons of others.)
I would guess the reason Supra guys can do single turbo conversions is because the Supra uses an I6 engine, not a V6. (right?)
Disclaimer: If you find any of the info I provided above to be incorrect, remain calm! A polite correction is always preferred over an angry flame.
Old Nov 15, 2002 | 01:48 PM
imntcrzy's Avatar
imntcrzy
I may be mistaken but I believe the 350 only has 1 throttle body, so a 2 turbo setup may have to be sequential rather than twin.
Old Nov 15, 2002 | 05:25 PM
jreiter's Avatar
jreiter
You can do twin turbos (as many as you like, actually) into one throttle body. Audi does this, for example. On their S4 and RS4, you've got a turbo coming off of each exhaust manifold. The compressor outlet pipes of each turbo just combine together into one just before connecting to the throttle body.
Old Nov 17, 2002 | 12:29 AM
JJH's Avatar
JJH
You can do a single turbo on a V engine. There is a kit out there for the LS1 Trans Am and Z28, which uses 1 turbo. A crossover pipe is used to connect the other bank to the turbo.
Old Nov 17, 2002 | 05:19 PM
TJZ's Avatar
TJZ
Default Re: Turbo vs Supercharger
I'm pretty sure this question came up before, but what is better, a turbocharger or supercharger. I know that the turbo will give you more horsepower, but the supercharger gives you instant power of the line? any suggestions?????
There is no "better". That's a stupid question. They're different and there have been multiple threads discussing the topic. Do some research and find out what you would like more.
Just to let you know, don't think that SC's require no maintance b/c people stereotype them to be so reliable. If you do any FI expect to do a lot of maintance or you will definately have problems (you know, if you "french fry" instead of "pizza")(i hope somebody got that).
Old Jul 3, 2006 | 01:59 PM
lex350's Avatar
lex350
This thread is Fuking OLD. I wounder how many people have changed there tune since they posted here. Is there even enough room for a twin turbo? Damn, I thought I had it bad now with this damn Rev-up, I'm glad I didn't buy a 350z when they first came out.. Respect to those who did.
Old Jul 3, 2006 | 02:07 PM
blue06z's Avatar
blue06z
Greddy makes a twin turbo kit, so I can only assume there is room.
Old Jul 3, 2006 | 02:52 PM
lex350's Avatar
lex350
lol ^
Old Oct 26, 2023 | 12:01 PM
TheRealLoner1's Avatar
TheRealLoner1
anyone know a good supercharger they would recommend for a 05 350z if possible ive been looking for one but all i get is a centrifugal supercharger?
Old Oct 26, 2023 | 12:40 PM
iideadeyeii's Avatar
iideadeyeii
Look into Thomas Knight supercharger
Old Oct 26, 2023 | 01:18 PM
DarkZ03's Avatar
DarkZ03
That's the best damn kind!
LMAO
Old Oct 26, 2023 | 05:28 PM
bealljk's Avatar
bealljk
Welcome to the forum Real Lone - you have revived a 17year old thread … might be a record! Regardless -
At this point in time I believe Vortech is (likely) the only company that is actively making superchargers these days…
Unless you are 10,000% deadset on a supercharger you should consider a turbo kit. You may have more options and better luck finding what you want.
Old Oct 27, 2023 | 12:20 AM
DarkZ03's Avatar
DarkZ03
HKS still does and soon Z1, but they are all centrifugal units.
Old Oct 27, 2023 | 03:46 AM
travlee's Avatar
travlee
Master
almost 19 years on this thread
https://my350z.com/forum/2003-2009-n...exhaust-2.html
Old Oct 29, 2023 | 03:05 PM
TheRealLoner1
Aslong as people still reply and talk I will always have questions and im deadset on a supercharger since that's what I've been grown up with my dad has had all kinds of supercharged trucks I'm just used to liking the sound
Old Oct 29, 2023 | 08:10 PM
bealljk's Avatar
bealljk
Perfect - I wont try to talk you out of it!
Vortech is probably your best bet at this point. They will have the most options and support for your the application
Old Oct 31, 2023 | 12:35 PM
VQplatform's Avatar
VQplatform
I'd go with an HKS kit. Much more torquey!
350Z_Al
Oct 29, 2020 07:44 PM
Calinismo350z
Sep 14, 2015 04:04 PM
