zeitronix graph pic with vortech sc
Old Feb 28, 2005 | 12:53 PM
backagain's Avatar
backagain
Default zeitronix graph pic with vortech sc
whats up all, here is a screenshot of my zeitronix software graph doing a 2nd gear run to redline, car is not fully tuned at the moment, running extremely rich to keep it safe until i have find time and money to get it tuned, with this tuning i am putting 380 to the wheels. along with vortech i have dc sport headers, topspeed test pipes, and borla td exhaust, let me know what you think.
here is a pic of the engine
this is the car it's installed on
Old Feb 28, 2005 | 01:14 PM
etx's Avatar
etx
sweet man, looks good. Little bit rich eh? How did you get a TPS signal?
Old Feb 28, 2005 | 01:17 PM
backagain's Avatar
backagain
tapped into the green ecu wire, use the zeitronix grey wire.
Old Feb 28, 2005 | 01:57 PM
CaneZMD's Avatar
CaneZMD
Backagain,
Do it yourself, tune it for free. You have all the tools.
Do two of those runs, back to back. Except this time put it in second and coast down to 1000 rpm, then floor it to WOT upto redline. You'll get a graph just like that with values from 1000rpm to 6600 rpm with the corresponding AF ratio. Then, hook up your laptop to the split second box and download the map. (see other posts about this) Adjust each value slightly more rich or slightly more lean based on the zeitronix graph. Then go "dyno" with the zeitronix and see where you stand.
About 3-4 cycles, and you'll be perfectly tuned. It worked great for me.
Old Feb 28, 2005 | 02:01 PM
backagain's Avatar
backagain
i guess i could do this, i do have the tools, but would hate to put in a wrong value in one of the cells and end up blowing it, i'll think about doing this, thanks a lot canezmd.
Old Feb 28, 2005 | 03:37 PM
damen's Avatar
damen
nice i just ordered mine and can't wait for it to arrive and be installed in the car.
Old Feb 28, 2005 | 04:28 PM
GQ 350z's Avatar
GQ 350z
Any impressions of the Vortech? Acceleration, 1/4 mile etc etc.
Thanks!
Old Feb 28, 2005 | 04:41 PM
backagain's Avatar
backagain
haven't had a chance to 1/4 mile yet. acceleration is crazy unbelievable. i have had a LOT of issues out of it though, aux fuel pump hose coming out, for about 2 weeks i couldn't rev past 4500 rpm at wot, adjusted the bov and it started working fine, but now, everynow and then when wot it will get what seems like limp mode, loss of power, car will not shut off but will not rev, turn off car, turn back on, car runs fine, i hope this is just limp mode and the car is taking care of me. any ideas gq ?
Old Feb 28, 2005 | 07:06 PM
booger's Avatar
booger
Reset the ECU . I went in a limp mode the other day . Reset the ECU and it hasnt done it since . Im thinking when we mess with or change stuff so much , the ECU gets confused or something , and goes in the limp mode
Old Feb 28, 2005 | 08:07 PM
amf813's Avatar
amf813
get some viagra if you are in limp mode....LOL
Old Mar 1, 2005 | 03:42 AM
zbicklin's Avatar
zbicklin
Do you have your ECU reflashed? I notices your Throttle Position was at 99% during your power run. Mine only reads 82-83 when I record runs on my Zeitronix. Thanks!
Old Mar 1, 2005 | 04:53 AM
CaneZMD's Avatar
CaneZMD
So this is one of my graphs. If you only make small adjustments, like change 10 to 10.2 or 10.1, it's pretty safe. I think your sampling rate might be low also.
My tps shows 100, but that's because I selected View->TPS-> calibrate to plot range. Before that, it always read like 87% or something.
Attached Thumbnails zeitronix graph pic with vortech sc-screenhunter_002.jpg
Old Mar 1, 2005 | 09:50 AM
kzanard's Avatar
kzanard
Default Limp mode issues
Backagain,
I don't want to hijack thread, but you caught my interest with the going into limp mode issue. I think I have the same issue. Before the winter on 3 occassions I was on highway gong about 65 and downshifted and punched it and my car all of a sudden would not let me rev (very dangerous - almost got rear ended twice!). If I did rev (even a little) it would bog down. I could cruise at about 1,400 RPM's max. on all occasions I pulled over and restarted the car and problem disappeared. I could not duplicate on purpose. I posted a few months ago but no one had experienced it. My car has been in storage for winter ever since but i will have to deal with it soon. If you continue to see the problem, we should recall my old thread or start a new one to try to figure it out. Good luck!
~ kz
Old Mar 1, 2005 | 03:16 PM
backagain's Avatar
backagain
i am almost certain that you went into limp mode, i am running a bit more hp than you but i guess it can happen at any hp over stock ??? just let us know how it runs when you get it out of storeage.
Old Mar 2, 2005 | 06:31 AM
kzanard's Avatar
kzanard
Default Re: Limp mode issues
Backagain,
We are putting downthe same HP, aren't we (380 to the wheels)? Anyway, thanks for reply. I will be diging into it in about 2-3 weeks or so an will let you know.
~ KZ
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
Tochigi_236
Sep 27, 2015 03:40 PM
