fuel pressure loss with AAM return system
Old Mar 2, 2005 | 03:53 PM
booger's Avatar
booger
Default fuel preasure lose with AAM return system
I noticed when I shut off the car for awhile and come back out . I'll turn on the ingnition and the fuel preasure is slowly dropping off . If I let it sit a day...its down to 25psi . Do you guys know where would be the first place to check ? I dont see or smell any gas . And my preasure gauge is hooked directly to the FPR
THANKS...Bill
Old Mar 2, 2005 | 04:06 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
one guy had a leak at the gasket where the fuel pump slips into the assembly. Might be the first place to check.
Old Mar 2, 2005 | 04:10 PM
booger's Avatar
booger
I'll have to pull the back seat out and pull the assembly out . What type of gasket is it ? rubber ?
Old Mar 2, 2005 | 04:34 PM
phunk's Avatar
phunk
CJ Motorsports
When you turn the ignition on, if you dont fire up the engine the fuel pump turns back off. You may not have a leak, depends on how rapid the pressure is dropping.
Old Mar 2, 2005 | 04:41 PM
booger's Avatar
booger
when I go out and its been sitting . I'll turn on the ingnition , the fuel preasure will read in the low 40's . It will not jump up to 50 , but drops off by about 1 to 2psi per minute
Old Mar 2, 2005 | 06:13 PM
phunk's Avatar
phunk
CJ Motorsports
yea 1 or 2 psi per minute sounds just fine... that doesnt sound like a leak at all, that is just cause the fuel pump turns off after a couple seconds unless you start the engine.
Old Mar 2, 2005 | 06:19 PM
booger's Avatar
booger
thanks Charles
apex locator
Jul 23, 2021 02:27 AM
