Greddy oil pan with JWT spacer
Old Mar 12, 2005 | 03:16 PM
ktown z's Avatar
ktown z
Default Greddy oil pan with JWT spacer
Does the Greddy Twins Oil pan have a 6 quart capacity. If it doesn't would you recommend using a JWT oil pan spacer with it to reach 6 quarts. Since my installer will have to remove the oil pan, why not add this mod? Thanks
Old Mar 12, 2005 | 08:24 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
I don't think the GReddy kit comes with an oil pan....
Old Mar 13, 2005 | 09:08 AM
350Now's Avatar
350Now
I believe the current production of the Greddy Kit comes with a Cast oil pan that will add an additional 1 quart vs. the 1st generation which is just the stock with some oil feed welded on. Just check your kit out.
Old Mar 15, 2005 | 08:03 AM
t32gzz's Avatar
t32gzz
If you do not have an extra capacity oil pan (larger than stock) you should at least buy the JWT spacer.
Old Mar 15, 2005 | 10:23 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
the new greddy oil pan is just cast and heat-sunk, but it is not increased in terms of oil capacity.
Old Mar 15, 2005 | 06:54 PM
ktown z's Avatar
ktown z
Thanks, JWT spacer it is!
burglapfd
Dec 6, 2020 01:04 PM
