1/4 mile times for Vortech owners?
Old Mar 21, 2005 | 09:47 AM
G352NV's Avatar
G352NV
Default 1/4 mile times for Vortech owners?
Thinking about going out and giving her a run or two. So I know what to expect what are your 1/4 mile times?
Old Mar 21, 2005 | 04:10 PM
G352NV's Avatar
G352NV
Bump
Old Mar 21, 2005 | 05:57 PM
Gman2004's Avatar
Gman2004
Have not got to the track yet. Here an automatic with 404whp.
http://www.dfwg35.com
Old Mar 21, 2005 | 06:04 PM
booger's Avatar
booger
He has alot on that car
Old Mar 21, 2005 | 06:25 PM
G352NV's Avatar
G352NV
Wow he does! Do you really need a reflash if you get a custom tune?
Old Mar 21, 2005 | 06:28 PM
aron's Avatar
aron
Gman204,
I'm running the same HP as you. What would you hope for 1/4 mi? My power comes on a lot quicker with the smaller pulley, I'm hoping that will help when I do get to the track. It will be my first run ever.
Old Mar 21, 2005 | 06:46 PM
booger's Avatar
booger
I would think a high 12 with a sub 2 second 60 ft. I had a very hard time getting under 2 sec. 60ft. Only have done it once . 12.98 at 108mph with 1.98 60ft.
Old Mar 21, 2005 | 06:51 PM
Gman2004's Avatar
Gman2004
I'd be with a 12.8/12.9 with my set up. Although, I've pretty much made up my mind....going tt very soon and will build motor within 9-12 months after the install.
Old Mar 21, 2005 | 07:01 PM
Gman2004's Avatar
Gman2004
Got this from another thread I was on. He is refering to the ecu flash.
One is you'll have a good base map to fine tune from, so you won't have to make large corrections with the emanage. Timing will be addressed. Also the throttle response will increase along with it remaining at 100% open till redline
Old Mar 22, 2005 | 08:33 AM
bhk1004's Avatar
bhk1004
what I dont seems to understand is how people that are going NA are getting into 12'z and people with superchargers on thier Z's are having issues getting into 12'z.... i mean julian, when he had his procharger was able to get into 12.1 and 12.2'z. doesnt seem to make sense why a blown Z should have issues getting into the 12z....
Old Mar 22, 2005 | 08:48 AM
booger's Avatar
booger
DRAG SLICKS...and a whole lot of time practicing launches . Sea level instead of 1,000 ft.
Old Mar 22, 2005 | 08:53 AM
homiusang's Avatar
homiusang
The amont of traction also comes in play. Sure a blown Z will have much more hp and tq than a N/A one, but they don't seem to get too much traction off the line and thus the higher #. Like someone have mentioned, get some DR or ET Streets and lots of practice and you will be good.
Old Mar 22, 2005 | 10:30 AM
Gman2004's Avatar
Gman2004
Originally Posted by aron
Gman204,
Just saw your sig. You have 25whp more than me.
The car in the link is not mine....I was just using it as a reference.
Old Mar 22, 2005 | 10:54 AM
G352NV's Avatar
G352NV
Isnt that car a Auto?
Old Mar 22, 2005 | 11:07 AM
Gman2004's Avatar
Gman2004
Sure is....
Old Mar 22, 2005 | 12:05 PM
G352NV's Avatar
G352NV
So mines should be a bit better. If all goes well I might take it out next wed. I would really like to see what I can pull before tunning and cats.
Old Mar 22, 2005 | 12:08 PM
Gman2004's Avatar
Gman2004
But remember out of the box with out a custom tune or additional mods you are probably around 330rwhp......DFW is at 404rwhp
I have top speed headers if you are in the market....
https://my350z.com/forum/showthread.php?t=114450
Old Mar 23, 2005 | 05:30 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
How is a SC Z from a roll. Can it take a C5 9/10 times?
Old Mar 24, 2005 | 06:56 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Most Vortech traps Ive seen have been around 110 mph. Id say it would come down to the driver. If the Z could get that slight jump or outdrive the C5 then Id say yes it will pull the Vette, would be too close to call you know....
Old Mar 24, 2005 | 08:57 AM
mcduck's Avatar
mcduck
My 1/4 mile times were atrocious the one time I went last fall. Very slick track.. Rockingham, NC. Best time I had was in the mid 13s... like just under 13.7. But my speeds were as expected though. Best trap was just over 111mph. I simply could not get traction. Hoping to try on a better (less slick) track this spring.
