Turbo Charging Legal?
Old Mar 24, 2005 | 01:37 PM
RedBird's Avatar
RedBird
Default Turbo Charging Legal?
Are any or all of these turbo kits street legal?
Old Mar 24, 2005 | 01:45 PM
teh215's Avatar
teh215
If you mean emissions legal, I don't think that any of them are.
Old Mar 26, 2005 | 08:42 PM
WSchli1672's Avatar
WSchli1672
Street yes, Emissons no - as of now. The APS TT they are working on. Peter APS is keeping us posted. It's on another post.
Old Mar 26, 2005 | 10:10 PM
turbo-maxima's Avatar
turbo-maxima
The only thing about emissions is air being let into the atmosphere before its combusted, like a blow off valve. And then a open wastegate being vented into the air and not going through the catalic converter. I think thats it.
Old Mar 27, 2005 | 06:11 AM
kjbalto's Avatar
kjbalto
For emissions you mean in states like Cali that have the CARB right? I'm in NY and we have emissions. Will these kits cause a problem?
Old Mar 27, 2005 | 05:56 PM
itsjoshufocker's Avatar
itsjoshufocker
is APS planning to get this turbo kit CARB legal? im planning to make my own turbo kit.. a single turbo that uses stock exhaust manifold and is easy to remove
Old Mar 27, 2005 | 06:49 PM
G3po's Avatar
G3po
Default Carb
Yes APS is planning to pursue CARB on the TT kit.
However; JWT's TT kit will prolley be the first to actually obtain an EO#.
Old Mar 27, 2005 | 08:40 PM
mrtomcat's Avatar
mrtomcat
what's the difference between street legal and emissions legal? If you don't have CARB exemption it ain't legal (at least in wonderful california )
Is it even possible to pass emissions with a BOV that vents into the atmosphere?
Old Mar 28, 2005 | 08:49 AM
G3po's Avatar
G3po
Default Carb
In Cali , running a non-CARB approved FI system is in effect "not-street legal". Most states only require a sniffer test with no visual inspection.
In Cali we have both. So, you could pass the sniffer just fine and still fail the visual (or vise versa, or both). To be "visually legit" you are supposes to provide a valid EO# for the installed kit.
Old Mar 28, 2005 | 09:48 AM
mrtomcat's Avatar
mrtomcat
thank you.
Now what about the BOV question: Is it even possible to pass emissions with a BOV that vents into the atmosphere?
Old Mar 28, 2005 | 12:34 PM
G3po's Avatar
G3po
Default Bov
thank you.
Yes as long as the BOV does not vent into the atmosphere during the loaded sniffer test. The basic test should not load the chassis enough to produce boost , so as long as the BOV doesn't leak or at least vents back into the intake ,during the test, it should be OK. Note the APS TT system uses a two stage BOV. Under most throttle releases under boost it will act as a bypass valve (not atmopheric). It will only fully vent (atmospheric) under a high boost dump condition.
Old Mar 28, 2005 | 12:36 PM
mrtomcat's Avatar
mrtomcat
good info, thank you!
Old Mar 29, 2005 | 10:56 AM
mok5's Avatar
mok5
How about having a built bottom end as well as changing the engine compression for a TT setup, will that automatically make you fail a sniffer test? Doesn't each make and model of a vehicle have baseline values the smog tech uses? Or does every car uses the same pass/fail values? Life is tough in CA!!
Old Mar 29, 2005 | 11:09 AM
Lagtime's Avatar
Lagtime
You'll make it through a sniffer test, I agree. But a kit using a BOV that vents to atmosphere under any conditions is not going to make it through the ARB certification process. Nor will the ARB folks take kindly to modified fuel systems or any tweaking of the stock ECU programming.
One of the long time providers of turbo kits to the Supra community has been working for close to a year now on a smog legal upgrade for the OEM turbo equipped MKIV. When asked about upgrading and ARB certifying the fuel system his reply is:
As to the fuel system, CARB will NOT approve any kit that changes electronic fuel system management. We might explore other ideas to modify the kit in the future for more HP, but lets get past this initial stage first!
Old Mar 29, 2005 | 01:27 PM
G3po's Avatar
G3po
Default internals
Lowering the static CR can be made to pass the sniffer, depending on other variables. The OEM CATS are enourmous overkill and can celan up quite a lot. If you don't disclose the internal mods to the station they won't know that the SCR is lower, nor will the ECU (from a code perspective) as long as you don't go crazy low on SCR. For example with 8.5:1 cr pistons, the ECU on a G/Z does not throw any CELs to the best of my knowledge. Alterations such as Forged and lightened componets have little bearing on the testing, but still should not be mentioned to a tester.
Old Mar 29, 2005 | 01:33 PM
G3po's Avatar
G3po
Default fuel system
WRT " a BOV that vents to atmosphere under any conditions".
For example take the APS dual stage BOV. For testing it should be quite simple to force the BOV into "bypass mode" 100% of time , in order to obtain an EO number. It then is up to the user to open the BOV for "off-road use" only JWT uses only a bypass.
WRT "modified fuel systems", there are many degreess to this. For example I
have a fully CARB approved SC system on my Dodge truck. The mods to the fuel system altered the fuel line and added two bank fired aux injectors, controlled via piggyback ECU.
Old Mar 29, 2005 | 02:17 PM
teh215's Avatar
teh215
I do not understand how/why a BOV could effect emissions since it is only compressed air. There are no unburnt exhaust gases being expelled. Luckily I have never had to deal with emission testing either here in VA or in PA.
Old Mar 29, 2005 | 08:11 PM
G3po's Avatar
G3po
Default Bov
actually to the CARB it's not "only" compressed air. The crankcase vent enters the tract prior to the BOV (prior to the compressor). So it is therotetically a possible path for cranckase gases to escape via the BOV as opposed to ingestion by the engoen as intended. Crankcase gas is nasty stuff. Remember long long ago the function of a "draft tube".
Old Mar 30, 2005 | 10:28 AM
SoFl_G's Avatar
SoFl_G
Also, it depends on the location of the BOV in relation to the MAF Sensor. Any thing that alters what the MAF sees is a big NO NO on the eyes of the emissions police.
Vigman
Nov 17, 2015 04:34 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
