CJM Fuel Rails - Now Colored and Polished
Old Mar 25, 2005 | 05:58 PM
phunk's Avatar
phunk
CJ Motorsports
Default CJM Fuel Rails - Now Colored and Polished
I just wanted to show you guys cause this is our first machined product to get anodized so I am all stoked.
I am now setup with a local anodizer and our fuel rails are available in color!
We are stocking them in blue anodized and high luster polished finish. Raw CNC finish is also available of course.
Price on the rails in blue or raw CNC finish is $395
Price for high luster polished is $415
Custom anodized colors are $445
I know custom color being $50 is pretty expensive, however just know that I actually get charged $75 per color setup, so I am actually eating $25 of that not to mention the special trip to the anodizing place.
Overall IMHO the price isnt bad for the nicest and best fitting rails available for the 350z and G35!
Standard blue will be shipped with all of our complete fuel systems now unless specially ordered.
-Charles
CJ Motorsports
Old Mar 25, 2005 | 07:21 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Sweeeet... looks great...
Old Mar 25, 2005 | 08:00 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
such a shame that these parts that are so pretty are not at all visible in the engine bay!
Old Mar 25, 2005 | 08:18 PM
VR3's Avatar
VR3
Looking good!
Old Mar 25, 2005 | 08:42 PM
mrtomcat's Avatar
mrtomcat
would that work for a NXL Direct Port Nitrous system, since NX does not have a fuel rail for the Z yet?
Old Mar 26, 2005 | 01:10 AM
350Now's Avatar
350Now
very nice.. do you have pricing for your full fuel return system (Single Fuel Pump set-up)?
Old Mar 26, 2005 | 01:36 AM
phunk's Avatar
phunk
CJ Motorsports
yes the full kit price actually just dropped $150... I have found the supplies for a better cost and decided to skip the entire wholesale thing all together cause no one else wanted to stock them anyway!
So the retail price has dropped from 1195 to 1045.
My fuel return system kit is the most complete fuel system kit for the 350z available. It is highly optimized to get the most out of a single pump and it will be required for my twin pump add-on when I am finished with the R&D on that (will be a while).
Not only is it the most complete, but it utilizes the highest quality components. My fuel lines are teflon core based rather then rubber, and the fittings are scratch resistent and very nice looking. The SS braiding is also rubber coated to prevent abrasion (SS braided lines that are not coated will slowly but surely saw thru anything they contact but are not secured to). My kit starts at the pump and even replaces the hardpipe under the car with an anodized blue pipe of 1/2" in size. My fuel system kit also reroutes the fuel lines so that they are no longer 1" away from your exhaust manifold or turbocharger... we run a whip up the trans to the back of the engine to keep the fuel lines further away from these extreme heat sources.
The list of components is as follows:
CJM Fuel Pump Output Fitting
Hose Assy #1 (coated SS braided teflon core) Pump to Undercar Pipe
Undercar Feed Pipe (Anodized blue aluminum 1/2" pipe, fits in factory clips)
Hose Assy #2 (coated SS braided teflon core) Hard Pipe to Rails (-8 to twin -6)
CJM Premium Fuel Rails (so nice, you will love how refined they are)
Hose Assy #3 (Twin -6 Rail output lines to regulator)
CJM Fuel Pressure Regulater (CNC machined adjustable regulator with gauge port)
Marshall 1/8" NPT Fuel Pressure Gauge (mounts in the regulator or can be replaced with an in-cabin gauge sensor)
Hose Assy #4 (coated SS braided teflon core) Return Hose (Fits in factory clip, -6 in size... our feed flows so good a -4 return hose couldnt keep up)
CJM Return Correction Kit (in-tank pump assy modification kit to properly route return fuel to maintain siphon and swirl pot jet functions)
Thanks,
Charles
CJM
Here are a couple pics that show the quality in some of the components:
Old Mar 26, 2005 | 07:49 AM
G3po's Avatar
G3po
Default G return
Thanks,
Charles
CJM
Have you fitted your kit ot a G yet? If not do you think the lines need to be lengthened?
Old Mar 26, 2005 | 11:00 AM
phunk's Avatar
phunk
CJ Motorsports
Have not fitted to a G yet. It seems in Chicago the 350z is a bit more popular, as I hardly ever have a G35 come thru my shop. Whenever one does, I will take the required measurements so I can adjust the feed and return lengths.
Old Mar 26, 2005 | 11:12 AM
kosmic's Avatar
kosmic
Nice kit. For somebody installing an APS kit, would they benefit from using this fuel return system over the one that comes in the APS kit?
Old Mar 26, 2005 | 11:44 AM
phunk's Avatar
phunk
CJ Motorsports
I see little purpose in using my fuel system with the APS Twin Turbo kit unless having adjustable fuel pressure is going to assist you in your tuning.
Old Mar 28, 2005 | 08:56 AM
G3po's Avatar
G3po
Default regulator
Does the regualtor you provide allow rates to be adjusted to over 1:1?
Old Mar 28, 2005 | 09:36 AM
phunk's Avatar
phunk
CJ Motorsports
no sir... this is not a FMU, its like any other fuel pressure regulator with a 1:1... I believe only the Vortech Super FMU doubles as a FMU AND FPR?? But I could be wrong, I have only used FMUs a couple times in the past... but they dud actually do their job pretty well.
Old Mar 28, 2005 | 12:46 PM
G3po's Avatar
G3po
Default RR regulator
Thanx I figured. But as an FYI below is an example of a rising rate regulator that has very adjustable slope. I guess you could call it an FMU I was ,at one time thinking of a RR set slightly higher than 1:1 , say 1.25:1 to avoid a full injector upgrade. (the MR2035, can have both base and slope adjusted).
For example the soon to be available APS "big fuel system" is a bit of an overkill for me.
http://www.bellengineering.net/Pages/products_FPR.html
Old Mar 28, 2005 | 01:04 PM
thawk408's Avatar
thawk408
What is the difference in this kit and the AAM one?
Old Mar 29, 2005 | 04:43 PM
phunk's Avatar
phunk
CJ Motorsports
sorry i havent updated my website in a while but I plan on doing it VERY soon like this week I hope and you will find all the information you could possibly need on there about my system. It is such a nice system it really needs its on website if I really expect people to buy it for how much it costs.
Old Apr 7, 2005 | 01:57 PM
phunk's Avatar
phunk
CJ Motorsports
Old Apr 7, 2005 | 02:19 PM
nitrous350's Avatar
nitrous350
Hello Phunk
I get little question on my AAM fuel return system
After I install the furl system my Fuel gauge ar going to crazy
1/2 tank to red light and red light to 1/2 tank gas
Do you have any recommendation I have to check?
Old Apr 7, 2005 | 02:47 PM
phunk's Avatar
phunk
CJ Motorsports
contact AAM and ask them for the return bypass correction. i sell them but they recently came out with their own version of it and i believe they offer it for free to those who already had their fuel kit.
or you could just throw it all in the trash and buy my kit j/k their kit is perfectly suited for what your doing.
Old Apr 7, 2005 | 03:05 PM
5thgenluder's Avatar
5thgenluder
I can vouch for charles the kit and the quality of the parts are amazing.. Thanks James
