Vortech on a 5AT?
Old Apr 6, 2005 | 06:45 AM
FaustOrFamine's Avatar
FaustOrFamine
Default Vortech on a 5AT?
Guys, I am thinking of going the Vortech S/C way, but I have a 5AT...can I go with the S/C? If so, is there anything I should be concerned more of since I have an AT rather than a MT? What I have found by searching has been rather inconclusive on this topic so any advice would be greatly appreciated. Thanks.
Old Apr 6, 2005 | 06:51 AM
bauckrob1's Avatar
bauckrob1
not sure vortec makes a sc for 5at but I know a guy with stillen sc on a G-35at. Its badd azz.
Old Apr 6, 2005 | 08:20 AM
Gman2004's Avatar
Gman2004
DFW has an 5AT and has a vortech.
http://www.dfwg35.com
Old Apr 6, 2005 | 08:38 AM
zachcrosen's Avatar
zachcrosen
There are a bunch of guys running the Vortech with a 5AT, soon to include myself!
Old Apr 6, 2005 | 09:07 AM
wfcall's Avatar
wfcall
There is absolutely no problem for running f/I with auto (as long as it fits) except one..........
You will not be able to go wide open throttle in auto mode without hitting the rev-limiter unless some other ????? mods are done; it shifts just fine in manual mode....
Incidentally the 5sp auto in the Z is the same one (except for different ratios) as the Nissan Titan and Armadaboth of which weigh more than 5000lbs and are rated at 9000lbs towing capacity.....
I don't think this tranny is flimsy by any means...
you WILL want to do a valve body upgrade to minimize slippage and extra wear on the friction surfaces in the tranny...
Old Apr 6, 2005 | 09:36 AM
SungNamZ's Avatar
SungNamZ
Over 7000 miles with NO problems with Vortech SC on 5AT. During install, did send ECU to Technosquare and had them do "Limited Flash". "Limited Flash" increased rev limit, removed speed limit and increased throttle from 85% to 100%. To find out more about "Limited Flash" visit: www.technosquareinc.com
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
