Sleeved/decked block problem.... going to do engine #4...
Old Apr 6, 2005 | 04:40 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Default Sleeved/decked block problem.... going to do engine #4...
Hey Guys
Here it goes... My AEBS sleeved/decked engine has got a leak between the water jacket and the combustion chamber at the #6 cylinder... either a sunk sleeve or a blown head gasket. Can't see why a head gasket could blow since I was never boosting when ths happened, but I think that the first overheat that I had might have contributed to its deterioration...
The leakdown result on that cylinder was about 90% (retention - 10% leak). The car does not overheat now and drives normally, only pushes out hte coolant into the reservoir on long drives... there IS a very very slight hint of antifreeze vapor odor when I come to a stop... but no steaming from the pipe...
I will be taking the car in on Friday, we'll know more after that. Any thoughts would be greatly appreciated. This truly sucks!
Either thinking of selling the car after putting in a stock engine... or going forward and fixing the current one... Son't know yet.
Old Apr 6, 2005 | 04:42 PM
MIAPLAYA's Avatar
MIAPLAYA
That wont be the first AEBS sleeve I've seen that sunk...I sure hope it isn't though....Good luck man...
Old Apr 6, 2005 | 04:49 PM
ravaz's Avatar
ravaz
I'd sell it. Your cursed.
Old Apr 6, 2005 | 04:58 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
my thoughts exactly... but still...
Old Apr 6, 2005 | 05:01 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
That sucks Gurgen, hopefully it isn't a sunk sleeve.
Old Apr 6, 2005 | 05:33 PM
bullseye's Avatar
bullseye
If I were looking at engine #4, I'd be strongly considering a VIKING FUNERAL. (A torch! Bring me a torch!)
Good luck, Gurgen.
Old Apr 6, 2005 | 05:50 PM
KShep's Avatar
KShep
Un-freaking-possible.....is all I can think of.
Old Apr 6, 2005 | 06:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I am so sorry Gurgen....your luck MUST turn around.
Old Apr 6, 2005 | 06:24 PM
daddyz's Avatar
daddyz
Wow,your luck has to change! Wish you the best.
Old Apr 6, 2005 | 06:26 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
gurgen:
i'll sacrifice a virgin for you...that should sort things out
Old Apr 6, 2005 | 06:47 PM
kjbalto's Avatar
kjbalto
Damn Gurgen I feel for you. Nobody deserves this many headaches. I know how badly you wanted this done right and it sucks that this had to happen. I would honestly say sell the car because who knows what is going to happen next if they ever get it together right. Then go buy a lottery ticket because your luck is going to turn around. It always happens like that. Keep your head up bro. If you decide to keep going, good luck!! I already thought you were one crazy **** for not giving up yet so I wouldn't put it passed you to go to #4!!!!
Old Apr 6, 2005 | 07:35 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Hey guys... thanks for the sentiments... It really does suck, but that whole thing with the luck turning around, at this point I am not so sure.. "3rd time is a charm" thing should have kicked in here. Maybe the sacrificial virgin will do the job...
Old Apr 6, 2005 | 07:37 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
BTW... My "UltimateSleeper" subscript must be what did it, the darn thing just sleeps, and never wakes up.. or, rather, it hybernates...for years at a time..
Old Apr 6, 2005 | 07:59 PM
350Now's Avatar
350Now
Sorry to hear of your current troubles Gurgen. Please share once you find out what is the culprit hopefully it's something simple to fix.
Old Apr 6, 2005 | 08:02 PM
MOTOP's Avatar
MOTOP
Was it when we were coming up Geary?
I'm surprised the CO sensor didn't show anything when we flushed the cooling system. The leak must be very minimal.
Don't hesitate to call me if you need any help.
Old Apr 6, 2005 | 08:46 PM
kosmic's Avatar
kosmic
Man, I've read your postings for several months now with all the problems you've had getting that car where you want it. I feel for you...that's a serious string of bad luck.
Maybe you'll have some GOOD luck and it will just be a head gasket with no motor damage. I hope so.
Hey Guys
Old Apr 6, 2005 | 09:28 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Andrew ---- exactly then... Remember that I didn't notice right away that the car had overheated, it must have been a few seconds (maybe as long as 10) before the car went into limp mode, at which point I definitely took notice...
Old Apr 6, 2005 | 09:29 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I sure will, as always...
Old Apr 7, 2005 | 05:24 AM
NismoGCoupe's Avatar
NismoGCoupe
If you keep having all these problems with resleeving your blocks why not just forget about resleeving your next block and just do the forged internals with a factory block?
Is AEBS offering to resleeve another block for free?
Old Apr 7, 2005 | 05:29 AM
g356gear's Avatar
g356gear
I am sure AEBS will cover the block fix.....but not all the labour to remove,teardown,rebuild, and re-install the new motor. I remember Gurgen mentioning he had confirmed that already. This whole scenario is taking the phrase " you gotta pay to play " to new levels.....unfortunately
