TD05H-20g Turbo Upgrade Installed
Old Apr 14, 2005 | 03:47 PM
bldrz's Avatar
bldrz
Default TD05H-20g Turbo Upgrade Installed
We just installed TD05H-20G turbos, ATS triple disk clutch, and TC reflash for 650cc injectors. We will dyno on Monday or Tuesday if weather is good. Will post updates and more pics ASAP. Thanks Eric
Old Apr 14, 2005 | 03:51 PM
g356gear's Avatar
g356gear
Things are starting to get crrraaaaaaazy
Old Apr 14, 2005 | 04:15 PM
002-M-P's Avatar
002-M-P
I was really contemplating whether or not these would fit. Now I know...can't wait to see some numbers on that.
Old Apr 14, 2005 | 04:21 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Wow, cant wait to see the #'s this thing produces. Off topic-obviously that guy has $$$$, yet why does he have a wide body kit with sheels that stick way in like that(in te rear)? I hate seeing widebody kits when owners cant even get a custom offset made to make it look right Ok Ill stop my ranting. BTW arent those #'s at 20-21 psi kind of low?
Old Apr 14, 2005 | 07:27 PM
aron's Avatar
aron
Yeah - these numbers are just outrageous - thats just tooo damn scary for me...how do you evven land traction in 5th gear?...unreal
Old Apr 14, 2005 | 10:29 PM
Secret Z's Avatar
Secret Z
20-21 psi is not the same as it is on an 18G...these are capable of a higher psi.
Old Apr 14, 2005 | 10:30 PM
Secret Z's Avatar
Secret Z
Glad to hear, I am interested in this myself as well.
Old Apr 15, 2005 | 12:15 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
I didn't think there was room for a larger compressor housing? Did you just use the 20G compressor in a 18G compressor housing?
What are your power goals?
Old Apr 15, 2005 | 03:00 AM
kudos's Avatar
kudos
I think those numbers were made with the 18Gs.
Old Apr 15, 2005 | 08:06 AM
bldrz's Avatar
bldrz
The wheels could have been a little wider. They are custom made from Kinesis Motorsports. They are 19 x 9 up front with 245/35/19 tires and 19 x 12 in the rear with 315/25/19 tires. The HP numbers were on the 18G's. For the turbos we had the 18G compressor housing machined for a 20G compressor wheel and cliped the turbine wheels. We are hoping to get over 650hp. Thanks Eric
Old Apr 15, 2005 | 08:12 AM
Enron Exec's Avatar
Enron Exec
How are you and your car doing kudos? You need to share some stories with us!
Old Apr 15, 2005 | 08:41 AM
bwzabodyn's Avatar
bwzabodyn
how many lbs of boost are you planning on running with the 20G's? 24-25ish?
can't wait to see the numbers... 700whp on race gas can't be too far off!
Old Apr 15, 2005 | 08:46 AM
bldrz's Avatar
bldrz
We should be around 20-24 psi depending on how our fuel system is.
Old Apr 15, 2005 | 09:18 AM
kudos's Avatar
kudos
I'm doing fine man, unfortunately no stories to tell, my car has been parked at SGP for quite some time now.
Old Apr 15, 2005 | 01:35 PM
Brandon@Forged
Thanks for the information. Need to update your website.
Old Apr 15, 2005 | 01:43 PM
thawk408's Avatar
thawk408
I have not heard anything on your car in ALONG time. Why has it been at SGP so long? You don't have to answer if you dont want to.
Old Apr 15, 2005 | 01:56 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
What brand and CR pistons are you running? (nevermind..saw it in the sig) thanks Nis!
Brandon@Forged
CP. 8.5:1 CR as per his sig.
Old Apr 15, 2005 | 02:28 PM
bldrz's Avatar
bldrz
We are updating our website as i type.
Old Apr 15, 2005 | 03:38 PM
aalzuhair's Avatar
aalzuhair
What intake mainfold are you using, if I may ask?
Thanks,
Az
