Output settings with Vortech
Old Apr 18, 2005 | 05:03 PM
MCopare's Avatar
MCopare
Default Output settings with Vortech
Can someone post up there output setting on the splitsecond software?
Old Apr 18, 2005 | 05:11 PM
MCopare's Avatar
MCopare
also your timing map if possible for reference
Old Apr 18, 2005 | 05:23 PM
MCopare's Avatar
MCopare
Old Apr 18, 2005 | 05:30 PM
MCopare's Avatar
MCopare
help
Old Apr 18, 2005 | 05:31 PM
booger's Avatar
booger
out put settings....PWM mode..preasure 0 to 30psi /5 vdc FS
output A mode .... aux fuel pump with abortive start time
output B mode....over RPM or preasure
output C mode...Inj. A and B over ? latched
over rpm...3000
over psi....2.5
Old Apr 18, 2005 | 05:36 PM
MCopare's Avatar
MCopare
fuel pump start pressue? run time? startup time?
Old Apr 18, 2005 | 05:38 PM
booger's Avatar
booger
0, 0 , 0.....dont need them...they do nothing
Old Apr 18, 2005 | 05:40 PM
MCopare's Avatar
MCopare
cool...thanks booger
Old Apr 18, 2005 | 05:51 PM
freezeg35's Avatar
freezeg35
over rpm...3000
over psi....2.5
im using output b mode over rpm and pressure as per mark at split sec.
Old Apr 18, 2005 | 05:54 PM
MCopare's Avatar
MCopare
what is the difference? Not sure about what each does.
booger's Avatar
booger
yes ...that the stock settings....either work
