Overboost on stock vortech pulley?????
Old Apr 27, 2005 | 07:38 PM
freezeg35's Avatar
freezeg35
Default Overboost on stock vortech pulley?????
Kinda weird, but im finding that in 1st and 2nd gear towards redline im hitting almost 11 lbs boost on my boost gauge. I assumed it was impossible to overboost on a supercharger, that the pulley regulates boost. Anyone have any ideas. Ive also noticed a few times that when im up in the high boost it feels like its falling on its face a bit, like its running out of fuel. Im running the stock rich map right now, and am installing a wideband air fuel tomorrow. Any ideas?
Old Apr 27, 2005 | 08:14 PM
booger's Avatar
booger
If the temps out are cooler you may see more boost . If you think it maybe on the edge of running out of fuel..DONT...go to redline till you have that A/F gauge put it . Dont blow your motor for not having the right gauges
Old Apr 28, 2005 | 07:05 AM
freezeg35's Avatar
freezeg35
How is this possible, pulleys dont allow overboosting. Im confused.
Old Apr 28, 2005 | 07:44 AM
booger's Avatar
booger
cooler temps make for more dense air . If you went to the same rpm in any gear , you will have the same boost level . You may have went higher in rpm's than you have before , or noticed
Old Apr 28, 2005 | 01:58 PM
zachcrosen's Avatar
zachcrosen
Are you gonna get in on the Kinetix Manifold GB?? I was told to keep you in mind for it! Cant tell you my source though.
Old Apr 28, 2005 | 02:13 PM
booger's Avatar
booger
Money became tight after I had to send the blower in . Plus I got a vacation coming in a couple weeks . So I'm going to have to wait . I know your source , and I'll have to thank him for putting a word in for me
Old Apr 28, 2005 | 04:44 PM
freezeg35's Avatar
freezeg35
I did talk to vortech today and they said they could send me a different pulley for the front or the jackshaft. I cant see a bigger one on the front fitting as there is maybe a 32nd of and inch clearance between it and the blower housing.
Old Apr 28, 2005 | 05:07 PM
booger's Avatar
booger
The SC comes with a 3.33 serp pulley . You can go smaller for more boost...3.125 and the 2.87 . If you go bigger...you would lose boost . And I dont think you could get a bigger serp pulley on . The cog pulley on the jackshaft [ other side of serp pulley ] is 32 tooth . You can go bigger there for more boost . BUT the only 34 tooth cog pulley that Vortech has is really wide [ 50mm ] and needs to be cut in half and milled . Even then its harder than hell to get it on . With the 2.87 serp pulley and 32 tooth cog [ stock ].....you are over spinning the suggested rpm for the blower already.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
