Vortech install problem
Old Apr 29, 2005 | 10:50 AM
zimbo's Avatar
zimbo
Seems like Fluidz had this same problem and it ended up being a bad SS box.
--Steve
Old Apr 29, 2005 | 10:55 AM
jpc350z's Avatar
jpc350z
[QUOTE=Phaneom]I used the Vortech manual, Harness manual, and the 2003 350Z service manual to check and mark sure they are all showing the same thing.
These are the pins (terminals) I used.
109 Ignition switch (power)
115 ECM ground
51 Mass air flow sensor
13 Crankshaft position sensor
33 Camshaft position sensor No.1
14 Camshaft position sensor No.2[/QUOT
If you also verified the color striping of the wires and have good contact then I would suspect the SS bOX..By the way how are you connecting into the patch solder / crimp ? Also verify + battery terminal and + terminal on the fuel pump..from the ss box..Good lUCK
Old Apr 29, 2005 | 03:46 PM
Phaneom's Avatar
Phaneom
Everything was soldered, and I really took my time doing it. I called Vortech and he said it sounds like it may be the SS box. So I just UPSed it back to them and they will be sending me a new one as soon as they get the bad one. It kind of suck that eveything is installed and I can't even driver her
Uriyo_
Sep 8, 2021 08:46 AM
