Rebuilding turbos- go with a 20g wheel?
Old May 3, 2005 | 08:58 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by Zues350ztt
Well up top highway at about 50mph this is where there will be a big diffrence between 400hp and 600hp.
that is for damn sure!!! throws you back in 5th gear--can't do that with 400 horsies!
Old May 3, 2005 | 09:03 PM
Zues350ztt's Avatar
Zues350ztt
Originally Posted by 350zDCalb
I have already talked with a few people about this in detail
i blew a turbo seal and have to get the turbo(s) re-sealed and whatnot--i may go ahead and go up a size in wheel to a 20g..my take on this--the turbo would not require as much speed to produce the same boost--this would take some of the stress off of the turbo...
if i port and polish turbo--this may reduce some of the increased lag that i would experience with the larger wheel
i do not plan to make much more power than i do now--so the only reason for doing this wheel chnage would be to reduce stress on the turbo and increase its life
any comments..please!?
TODD
Thats a nice setup I have the same one changed the wheel to a 20g, but your going to need to change your wastegate spring it wont hold.
Old May 4, 2005 | 03:23 AM
westpak's Avatar
westpak
SFZCC
A turbo timer is probably a good idea as well to help with coking of the oil inthe turbos.
Old May 4, 2005 | 09:22 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
i have a .8bar wastegate spring
350zDCalb's Avatar
350zDCalb
builtZmotors
i've let my car run for at least 1 min 20 sec everytime i shut her down (with a greddy turbo timer)
Old May 4, 2005 | 09:47 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
please explain your setup in greater detail...how much lag to you experience (at what rpm to you start seeing boost/ see full boost?) how many pounds are you running???
TODD
Old May 8, 2005 | 08:28 AM
Zues350ztt's Avatar
Zues350ztt
TODD
I have the wheel swap for the turbo to a 20g you start seeing boost at about 3krpm you dont see full boost till 4500. Not bad cause on the 18g I would see full boost at about the same. I dont have a greddy E manage I am using DTA enginemanagment it has full turbo anti lag facilities. This week I ll send you my dyno numbers I will be tuned by this week 24-25psi for sure. The only reason I said to change your wasgatespring is because you wont be able to go over 22psi cause your spring can only double its lowest number .8 with boost controller can only go up to 1.6bar with boost controller with a 20g you would like to run 25psi so go with a 1 bar spring especially if you are running with 8.5:1 compression low compression loves high boost. I will pm you my numbers in a week or so.
Old May 8, 2005 | 08:48 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
I have .you would like to run 25psi so go with a 1 bar spring especially if you are running with 8.5:1 compression low compression loves high boost. I will pm you my numbers in a week or so.
thx for the info, i'm actually running 9.0:1 CR, and i am content with the power i'm making now, i think i'm gonna keep my car on a 14psi tune and have a high boost setting of 17/18psi...i really don't need all that power(not using it anyway).... and i want things to last as long as possible
Old Jul 13, 2005 | 03:00 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Bump.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
