inline fuel pump
Old Feb 11, 2010 | 12:15 PM
accordfreak's Avatar
accordfreak
oem tank feed to the surge tank, surge tank to the inline, return line to the surge tank, surge tank overflow line to the oem tank.
Old Feb 11, 2010 | 06:23 PM
midz350's Avatar
midz350
from AAM website:
Old Feb 11, 2010 | 08:05 PM
nomyth46's Avatar
nomyth46
wow.............old theard
Old Feb 12, 2010 | 05:23 AM
Cass007's Avatar
Cass007
jtgli, where you going to mount that surge tank? Did you ever get the stock lines out of the tank yet?
Old Feb 12, 2010 | 09:59 PM
phunk's Avatar
phunk
CJ Motorsports
if youre going to run a combination of the stock fuel tank and an external surge tank in a 350z/g35, do yourself a favor and do not plumb the lines anything like that chart posted above. rather, pay attention to what accordfreak said just before it, and use a return correction kit for the surge tanks overflow.
Old Feb 13, 2010 | 03:45 AM
midz350's Avatar
midz350
^^ You mean like this:
Old Feb 13, 2010 | 09:09 AM
phunk's Avatar
phunk
CJ Motorsports
yes that is the way to do it... just to make it 350z/g35 specific tho, you would need to add that the fuel return re-enters the stock fuel pump assembly via a return correction kit. this allows the siphon to be active any time the surge tank is full, which will be almost always (a walbro filling a surge can will be able to outflow the bosch feeding the engine, pretty much all the time in most applications. expect the surge canister to only be less-than-full when the vehicle is turning under conditions that will be starving the in-tank walbro, such as road racing. also expect to replace that in-tank pump every so often under those conditions, because walbros dont last long when you let them starve).
Old Mar 25, 2010 | 02:25 PM
overZealous1's Avatar
overZealous1
output flow ratings are based on psi. with an inline pump the first pump DOES NOT always determine limits of the fuel system. if the first pump runs in freeflow it will supply far more than rated at 40-50psi, the second pump then creates the pressure, thus giving it it's fuel output rating. the first pump will help the second one create the psi set at the regulator. both give eachother a helping hand. as long as your second pump is larger, no sweat. get it? got it!
Old Mar 26, 2010 | 09:19 AM
ADMAN's Avatar
ADMAN
...you can also just run a bigger wire to the pump and you'll be fine.
Old May 17, 2010 | 08:49 PM
binder's Avatar
binder
so the question was never answered:
is a surge tank required to get more fuel or can you run just an inline 044 and show results?
kyin
Oct 15, 2015 05:54 AM
