do i have the strongest vq35?
Old May 7, 2005 | 03:20 AM
overZealous1's Avatar
overZealous1
Default do i have the strongest vq35?
well some have seen my posts in the past, and i have still been waiting (even trying to a point) to throw rod out the block, but dam, it still keeps going. running 12psi on an ati with stock internals and no dyno tune. getting 5-6 psi at 3000rpm and setting off the maf limp mode on occasion too.
not too sure what people are doing to blow solids out the sides of the block, but mine is still holding. just have it set rich on boost and well thats about it. got an emanage on its way, but almost afraid to get it tuned so they don't mess up my good luck streak, hahaha.
some will bring into the idea of "washing the cylinders" by running rich as bad. and granted it is, but alot better than using your block as a picture window!! like i said, still running today, check back tomorrow!
maybe i am just not pushing it as hard as others. but even the stock clutch seems to hold ok. granted, it spins the tires in 1st, 2nd, 3rd, and well till i take my foot out of it, maybe if it was trying to hook up more i would see more slippage ( tilton semi-street is ready to go in)
just making me curious why mine is holding and others are not!
Old May 7, 2005 | 05:18 AM
mcduck's Avatar
mcduck
Vortech running 9.5-10psi at peak, stock internals, 425rwhp, 17,000+ miles
BTW, you may think the stock clutch is holding up ok, but its probably not. I thought the same thing. Then I went to Nissan to have the tranny replaced under warranty and they gave me a new clutch to boot. The difference was night and day. The clutch, like the spark plugs, are parts that gradually degrade over time. You won't notice how much they have worn down until you put a new one in.
What did you dyno with the ATI at 12lbs of boost?
Old May 7, 2005 | 06:56 AM
leemik's Avatar
leemik
overZealous1 are you still running the DFMU and pump or did you rip it out when you got the injectors?
--mike
Old May 7, 2005 | 07:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You did retard your timing right? If so how much? BTW, before you tune it, you should get a baseline of what your at now-hp/tq #'s and a/f #'s Im curious what kind of set-up you have to keep the motor alive at that boost level.
Old May 7, 2005 | 07:18 AM
westpak's Avatar
westpak
SFZCC
It seems that the ones not taking to high boost well are the TT's probably because where you see 5-6 psi at 3000 RPM a TT will see almost max boost at that time, so like myself I am running 8.5 PSI I see that by 4K.
Old May 7, 2005 | 08:10 AM
Enron Exec's Avatar
Enron Exec
I dont know how you can run 12lbs on the ATI w/o pulling timming. Please tell me you are pulling timming.
Old May 7, 2005 | 08:30 AM
FairladyZ's Avatar
FairladyZ
If he is running rich he is ok. Thats the whole point. He is very safe because he is running rich. With that said I am sure I can blow it up for you. What did you dyno?
Old May 7, 2005 | 08:59 AM
narkotic's Avatar
narkotic
You guys realize that the SFR/SSR turbo kit pulls no timing whatsoever, and is able to make tons of HP at low boost (6.5-7.0). Theres just no solid answer to "correctly" tune the vq35.
Old May 7, 2005 | 09:59 AM
etx's Avatar
etx
Quoted for laughability.
I think you mean no settings are going to work acrost the board for all FI VQ's.
Old May 7, 2005 | 10:39 AM
overZealous1
yes i plan to see where it is at right now hp/tq wise, then tune from there. i am still running the aeromotive fmu set at what ati tells you to set it at. but with the larger injectors it is making a bit rich. no timing has been pulled what so ever but am running the colder plugs.
as far as hp goes right now, not sure. i also have a full solid rollered 383 vette putting out 560hp (@ crank) and my Z would definately give it a run for the money.
i have the greddy emanage on it's way right now to put in the car and get rid of the aeromotive fmu to be able to pull timing and get more precise with the a/f ratio. the aeromotive works good, but i don't feel too safe running fuel pressures that high w/o having all braided fuel lines.
Old May 7, 2005 | 11:15 AM
G352NV's Avatar
G352NV
Go knock on some wood fast!
Old May 7, 2005 | 06:40 PM
narkotic's Avatar
narkotic
That is what I meant ETX. No need to be mr. a55hole as usual.
sales@czp
Sep 23, 2019 03:30 PM
McBickBick
Jun 30, 2004 05:14 PM
mchapman
Australia/New Zealand
Apr 13, 2004 12:27 AM
fairladyZ in Japan
Jan 21, 2004 12:40 PM
