Vortech - Gates belt walking off idler pulley
Old May 13, 2005 | 06:41 AM
jpc350z's Avatar
jpc350z
Originally Posted by gspot35
JPC- Boost should come up with RPM...you probably can't make full boost in 1st gear, but every other gear should give you 8psi near redline. I make very little dust if any as do a lot of other people.
Sunset- are you sure you have no vacuum leaks? Is your idle stable for 2-3 minutes straight? You could have your cog belt idler too tight creating too much resistance. If you have belt dust, it's caused by friction. Either by mis-aligned belts or loose belts. Remember the load increases on the s/c as boost builds, so slippage will occur at high rpm where it's hard to see. Good luck in your hunt.
Boost begins at rpm but takes awhile to get full 8psi..
Old May 13, 2005 | 06:43 PM
mysunset's Avatar
mysunset
gspot - From what I can see, all vaccuum lines are good. no kinks and smooth bends throughout - the car idles great. Before driving the car, i make sure it is warmed up before heading out. I will agree that dust would be caused by friction, that is what I figured.
I will look again at the cog pulley, and review all the vaccuum lines. Maybe I missed something. I am leaning towards mis-aligned at this point, but the thought about the cog idler pulley may be worth investigating.
Thanks again for your input
Old May 16, 2005 | 05:29 PM
mysunset's Avatar
mysunset
Talking
gspot- after removing the shims i had installed, the plate alignment is 10 times better. Not sure why some are suggesting placing shims/washers behind the mounting to align the belt better, but in my instance it was not a viable solution.
thanks for all your assistance.
Old May 17, 2005 | 05:41 AM
gspot35's Avatar
gspot35
Awesome, glad to hear you got it.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
