Finally coming together
Old May 14, 2005 | 01:48 PM
booger's Avatar
booger
Default Finally coming together
Well after months of trying to figure out my problems with idle and starting after the rebuild . Its finally coming together . I couldnt figure out why the car wouldnt start or idle very good . After rebuilding the short block , adding a return fuel system , 550 injectors , and cams , I just couldnt get it right .
I finally figured out it was the wiring of the Zietronix datalogger . The shop used crimp type connectors and it screwed up everything . I had them redo them the other day . I got the new T-trim blower on and got it started yesterday . Idle is great and A/F is stable ,and it starts very good . I will be road tuning to get it close and then hit the Mustang dyno to tune it further . With the help of 2JZFan . I hope to get 14psi out of the T-trim blower .
I would like to thank...Phunk...2JZFan..and GQ-626...for thier advice and every one else that contributes to this forum . I seem to learn the hard way...by making mistakes and learning from them . Spending money where I dont need to and finding out it doesnt work . I will post how it goes in the next few weeks with the tuning .
Bill
Old May 14, 2005 | 04:19 PM
tig488's Avatar
tig488
good luck, post some high numbers!
Old May 14, 2005 | 05:05 PM
Z33Concept's Avatar
Z33Concept
Good Luck Booger
Old May 14, 2005 | 05:55 PM
booger's Avatar
booger
took it out for a little drive tonight . 5 psi at 3000rpm..partial throttle . Got some work to do tunung it again .
Old May 14, 2005 | 07:13 PM
Gman2004's Avatar
Gman2004
Good to hear that things are coming together. I can't see what the final numbers are. Good Luck!
Old May 14, 2005 | 09:25 PM
tig488's Avatar
tig488
^...wait to...^
Old May 14, 2005 | 09:27 PM
Gman2004's Avatar
Gman2004
Wow! I really fuked that one up, huh?
Old May 15, 2005 | 04:30 AM
booger's Avatar
booger
I got the idea.....thanks...
Old May 15, 2005 | 05:01 AM
Jaki's Avatar
Jaki
Good Luck.
Old May 15, 2005 | 11:16 AM
luanda's Avatar
luanda
Hey booger...mind me asking how much it cost for Vortech to rebuild your SC?? and what the max RPM rating now?
Old May 16, 2005 | 05:49 AM
blubyu's Avatar
blubyu
have fun with that T-trim.
Old May 16, 2005 | 05:50 PM
booger's Avatar
booger
I was mistaken on the boost at 3000rpm...it 2.5psi . Im seeing 11 to 11.5 at 6000rpm now...havent got to redline yet
Old May 16, 2005 | 07:30 PM
Phatmitzu's Avatar
Phatmitzu
Cant wait to see the numbers.
Old May 16, 2005 | 07:32 PM
Barzten1's Avatar
Barzten1
Good luck Boog
Old May 17, 2005 | 10:14 AM
t32gzz's Avatar
t32gzz
I am glad you are idling well again. I would have not have thought to look into the datalogger wiring.
Old May 21, 2005 | 09:02 AM
booger's Avatar
booger
I got the car up to 6,800rpm . Boost builds to 11.7psi at 6,300rpm and then drops off to 10.5psi after 6,300rpm's . I pressurized the whole intercooler , pipes , intake manifold , and motor . I put it at 25psi . I found 2 small leaks in the intake manifold , but nothing to stop boost from building . Im thinking the blower is either starving for air , or there is to much restriction in the intercooler or pipes . And maybe belt slipping [ its tight ] but still a possability . Any suggestions would be helpful
Old May 21, 2005 | 11:54 AM
bullseye's Avatar
bullseye
Back pressure in your exhaust system...?
Old May 21, 2005 | 12:00 PM
booger's Avatar
booger
Headers , dual Stillen , Crawford cats....the cats may
Old Jun 4, 2005 | 06:38 PM
booger's Avatar
booger
Smile
The boost leak in the plenum was bigger than I thought . I put a second gasket on and now have it up to 12.8psi and it still leveled off form 6,300rpm to 6,800rpm . I preasurized the plenum again and it still is leaking . Not as bad . A third gasket will go on Monday and tested one more time . Dyno tune it Tuesday . I put 25psi in it and my boost gauge read 18.5psi . The BOV held the preasure. If I can get the leak fix , I hope to get a little over 13psi at 6,800rpm .
Old Jun 4, 2005 | 07:20 PM
G352NV's Avatar
G352NV
Wow cant wait to see your HP #'s! Nice to see someone with a Vortech taking it this far.
