Misfire in cylinders
Old May 23, 2005 | 08:09 AM
Jon@ptp's Avatar
Jon@ptp
at least thats what our tech says to start out with
Old May 23, 2005 | 05:17 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I think he has a random cylinder misfire, so its not just one cylinder. The random cylinder misfire is read by the ECU by minute changes in the acceleration of the crank..via crank angle sensor. If one cylinder doesnt fire...the crank angle sensor will pick up this abnormal crank behavior..and trigger the code.
Old May 24, 2005 | 12:49 PM
devil_z33's Avatar
devil_z33
I will bring my car to my mechanic to have them check today. Hope can solve the problem.
Old May 25, 2005 | 09:43 AM
joshcrz's Avatar
joshcrz
po300 is ramdom multiple misfire-but thats just becuz the computer hasnt isolated it yet.you can do this is manualy by removing the coil plugs 2 finds out which cylinder is faulty then isolate if it is injector or coil
Old May 25, 2005 | 09:45 AM
devil_z33's Avatar
devil_z33
I had my mechanic to check my engine yesterday. He said the spark plugs and coil are fine. He said the reason of paining during acceleration around 3000-4000 (in boost) maybe because the emanage running rich. however, the emanage has a code lock and he cannot adjust the fuel map. I wanna if I had my ECU to have TS reflash, would that solve the problem?
Thanks.
Old May 30, 2005 | 03:15 PM
joshcrz's Avatar
joshcrz
we have tuned several z's and they do run very rich but we havent see them do anything that ur describing. i had one that would misfire and it turned out to be the injector. and it the only time ive seen and RC injector fail.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
allmycarsdie
May 13, 2016 04:38 PM
kyin
Sep 29, 2015 06:57 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
