Misfire in cylinders
Old May 21, 2005 | 08:35 AM
devil_z33's Avatar
devil_z33
Default Misfire in cylinders
Hi, I have a question to all have your TT installed. I am running a one step colder than stock iridium spark plugs. However, there are many misfire at idle speed and when I accel. to around 3000-4000 RPM. I did gapped to about .035. When I do the first test run after the gapped, it run smooth and did not have misfired at all. However, after turn off the engine, and start back on in like 30 min. It started misfire again, and the "engine service soon" light come on. Anyone know what that cause happen?
Please help. Thanks
Old May 21, 2005 | 09:24 AM
baileyrx's Avatar
baileyrx
asuming your timing is correct... I've read where twin's need the much more expensive 2-step plugs
Old May 21, 2005 | 09:31 AM
g356gear's Avatar
g356gear
The computer will sometimes read a rich condition as a misfire. Is this the stock computer program that came with the kit??
Old May 21, 2005 | 09:33 AM
devil_z33's Avatar
devil_z33
It is stock computer with E-manage.
Old May 21, 2005 | 09:34 AM
mikebranson's Avatar
mikebranson
double check the gaps - sometimes when putting the plugs in - if you drop them in it can ruin the gaps. Happened to me once before - just an idea.....
Old May 21, 2005 | 09:35 AM
devil_z33's Avatar
devil_z33
I did not drop it. For sure..=)
Old May 21, 2005 | 09:36 AM
g356gear's Avatar
g356gear
The stock Greddy map is notoriously rich. That is probably why your ecu is reading a misfire code. There are a few guys around with better maps on the boards..amybe put up a request post for help.
Old May 21, 2005 | 09:44 AM
devil_z33's Avatar
devil_z33
But I did felt the engine is misfireing. And also, when I accelerate to around 3000-4000 rpm, the engine misfire like terrible. Does that engine running rich or it is misfire?
Old May 21, 2005 | 09:58 AM
350G's Avatar
350G
If it feels like a misfire, then research the issue . . . My stock Greddy setup did fire a few codes in the first few months, but when I changed out to test pipes, it ran rather well. No problems here.
Old May 21, 2005 | 10:02 AM
devil_z33's Avatar
devil_z33
I had done many researches, i did check the gap of the spark plug. It run very smooth on the first test, but misfire again from the second run.
Old May 21, 2005 | 12:16 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
i run one step colder with 16psi-tt setup
Old May 21, 2005 | 12:53 PM
devil_z33's Avatar
devil_z33
Did you have any misfire problem?
Old May 21, 2005 | 01:03 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
no
Old May 21, 2005 | 01:32 PM
mrrsx350z's Avatar
mrrsx350z
might be the MAF, i had problem with just a cold air intake, CEL came on fem sec afterward. I took to the dealers ask them why my car was misfiring, they said bad MAF. Check that out. But I don't know that it might be the same for you cuz you got a TT kit.
Old May 21, 2005 | 01:34 PM
devil_z33's Avatar
devil_z33
If so, what spark plug are you using, and what you did you gap?
Old May 21, 2005 | 01:37 PM
devil_z33's Avatar
devil_z33
Correct me if i was wrong. I think it just like stock engine when it was at idle speed right. Also, I had a hard to start the engine once it warm up. Need to press the gas panel once to help to start the engine. Anyone had any opinion? Please help
Apprecicated in advance. Thanks
Old May 21, 2005 | 03:02 PM
zimbo's Avatar
zimbo
I have nothing to add to the solution, but want to say that if you can actually feel/hear a misfire then you should be very careful and not boost until the problem is diagnosed.
--Steve
Old May 22, 2005 | 06:28 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
devil, have you dyno tuned this car? If your AF ratio is very rich or lean, it will misfire, and throw the code. If you timing is overly advanced or overly retarded, that will also trigger a misfire.
There are so many things that can contribute to a misfire, but its highly unlikely its just your spark plug gapping. My guess is that if you have the stock Greddy map, you are running very rich in the low to midrange power band.
Old May 22, 2005 | 09:31 PM
devil_z33's Avatar
devil_z33
Yes, I have not dyno tuned my car yet because I have no idea where is a good place for e-manage dyno tune. Also, my mechanic try to upload the data from the emanage, but he said the emanage is locked. Anyone know a good place for dyno tune in Los Angeles areas.
Thanks for your opinion.
Old May 23, 2005 | 08:08 AM
Jon@ptp's Avatar
Jon@ptp
have u scaned the ecu and found out which cylinder it is? and when u do switch the coils and see if the misfire travels with the coil. simple test that u could do
