just blew up the motor...need help..!!
Old May 30, 2005 | 12:19 AM
chocoboy81's Avatar
chocoboy81
Default just blew up the motor...need help..!!
i had greddy tt set up and just blew the bottom part of the motor..
it has nasty hole that i can say the rod is broken....
does anyone know where i can get new block,rod,piston,and etc?
and wut else should i change with the motor?
and wut kinda ecu should i use???
Old May 30, 2005 | 12:24 AM
Johntuki's Avatar
Johntuki
http://store.yahoo.com/sgpracing-store/sgpravqmo.html
If I was in your situation I would attempt to get one of those from SGP. Very sorry to hear about your engine though man.
Old May 30, 2005 | 12:33 AM
sentry65's Avatar
sentry65
the burninator
sorry to hear about your engine man, but shouldn't you already know all this stuff if you're going FI in the first place?
I agree, go with SGP racing and get yourself a built engine, they'll guide you - costs some $$$$ though
Old May 30, 2005 | 02:29 AM
Z BOY's Avatar
Z BOY
and another one gone, another one gone, another one bites the dust. hey, gonna get you too...compliments of freddie mercury.
sorry for your loss.
how must boost were you pushin?
Old May 30, 2005 | 02:48 AM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Wow! That sucks and soeey to hear about your motor. It seems as though motor after motor keeps blowing.
Old May 30, 2005 | 05:12 AM
Gman2004's Avatar
Gman2004
Sorry to hear you blew your motor. If you've never built a motor, I would recommend SGP. Using them will take out the guess work. It will be a one stop shop. Not only that they have built several vq's and have the experience.
How many psi were you running? Did you have a pressure sensor harness and timing harness?
I'll give it a few minutes before this thread turns into APS is the best and how Greddy sucks.
Old May 30, 2005 | 05:19 AM
manny007's Avatar
manny007
go to www.forgedinternals.com, they have everything you will need to build a better and much stonger motor.
Good luck
Old May 30, 2005 | 06:45 AM
westpak's Avatar
westpak
SFZCC
Freddie rocks, sure hope I don't get got, 12k miles and 9 months and still running.
On topic, can you give some details such as when it was installed, how much boost you were running, what other mods do you have, it is nice to know specifics to see if it is something really wrong or probably another install issue.
Old May 30, 2005 | 07:03 AM
joshbrittain's Avatar
joshbrittain
^^^ what he said. details, details, details. sorry to hear about it.
Gman, I have the same prediction.
Old May 30, 2005 | 07:16 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Choco...give us the full story of what happened. When was the kit installed, how was it tuned...or was it tuned, boost level, fuel system upgrades..timing harness...shielded CAS?? More details the better.
Old May 30, 2005 | 07:53 AM
Dirty Dave's Avatar
Dirty Dave
Sorry to hear man, only if you would have seen my post I did a few weeks ago, I was in the same boat , it sucks real bad. Could have saved your motor. I have done alot of research, pm me and I can help ya get everything back together.
Old May 30, 2005 | 07:57 AM
xxlbeerZ's Avatar
xxlbeerZ
Seems like the Greddy shouldn't even be used without a motor buildup.
Old May 30, 2005 | 08:31 AM
chocoboy81's Avatar
chocoboy81
it wasnt really tuned..but only the e-01.
i tried to use boost at 7psi but the stupid machine couldnt learn the boost.so i decided to use the manual mode with 0 duty and 0 gain which pulled about 7.5~8 psi.
so i brought it to the track and ran 13s with stock boost.then i turn on the boost.
the car was running well 1,2,and 3rd gear and i shifted to 4th.after shifting and put on the gas,i heard the blow up sound and the motor went off..
i put the tt in 2004.11 and finally went dead.
other mods that i was running were injen exhaust,and test pipe.
i didnt have time to do the timing and else..
Old May 30, 2005 | 08:40 AM
chocoboy81's Avatar
chocoboy81
i also wanna know which to get on
this webbie...
and how's this one
http://www.aebsracing.com/products.p...ct=vq35stroker
and should i change the ecu or something since the motor has changeed?
or have to play with stupid e-manage??
Old May 30, 2005 | 09:14 AM
etx's Avatar
etx
Heh. I wonder how he blew it up. Geez.
Old May 30, 2005 | 09:39 AM
chocoboy81's Avatar
chocoboy81
i got a vid in my comp but no idea how to upload it.
if there's method i can show u tho..
Old May 30, 2005 | 10:14 AM
Sharif@Forged
Forged Performance
xxx...there is always more to the story. ANY forced induction kit can blow up if used improperly, or tuned, or the proper installation techniques are not adheared. And I am the first to admit, the Greddy kit is far from complete right out of the box. But with proper setup, and a couple of additional modifications, it can be just as safe as the other kits on the market...if not safer.
In this case, its unfortunate, but it appears that the boost was increased without any additional tuning or fuel provisions. I would certainly not be blaming it on the Greddy kit.
But realistically, with any Forced Induction applications, you are approaching the reasonable limits of the stock internals at about the 425whp mark. Yes you can run more power, and some have..but its a danger zone that I wouldnt want to be in.
Old May 30, 2005 | 10:51 AM
GZire's Avatar
GZire
+1 on SGP. I'll also plug http://www.forgedinternals.com/main.htm for parts and advice.
Gman2004 you trouble maker.
Old May 30, 2005 | 11:26 AM
westpak's Avatar
westpak
SFZCC
Right there you have it, increasing boost without fuel or timing being addressed. On manual mode and 0's on the settings should have given you 5-6 psi so you had something else going on maybe a faulty wastegate install.
Did you have a wideband 02 sensor to monitor the AF ratio? On your e01 what is the peak psi registered?
Old May 30, 2005 | 02:24 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
sorry about your loss...i have been there...
not to sound like an a$$, but why didn't you read up on this a bit and learn more about the setup before running 8psi with no other upgrades??!!!?
there is tons of info and preventative tips on how to run this kit safely...many of us have gone through this several months ago..wondering why you didn't learn from out mistakes...?
anyway, i feel for you, pm me your e-mail and i'll send you some lists of parts you'll need for the rebuild
TODD
