Turbonetics Kits--$4720 shipped to your door
Old Jun 11, 2005 | 07:08 AM
  #41
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by nexstage350
okay this might sound stupid, but hey i just dunno? what is the difference in the tuner version and the regular turbonetics kit? what do we all have to do to get the one with the CAT version for us emission sensitive states? basically what to we request when we order this particular model?
Looks like Brandon answer your question on the difference between tuner and regular version.
To order the cat version, just place this in the "comments" section of the website, and that you want the "my350z.com pricing special, and the $300 cat upgrade". I will take care of the rest, and add it to your invoice.
Thanks!
Old Jun 11, 2005 | 10:01 AM
  #42
nexstage350's Avatar
nexstage350
Thanks!
thanks for the quick response! one other quick question. do happen to have pix of the cat? i just want to see what this version looks like. the monting and etc... thanks
nexstage350
Old Jun 11, 2005 | 11:25 AM
  #43
axxizzer's Avatar
axxizzer
well, how will I know when the Auto with cat comes out?
Old Jun 11, 2005 | 11:50 AM
  #44
bio911's Avatar
bio911
if you compared the APS TT to the ST how to they stand up against each other on a stock motor?
Old Jun 11, 2005 | 01:39 PM
  #45
Sharif@Forged
Forged Performance
At this point, its impossible to say, since nobody has installed a single T APS kit here in the states.
If you look at the kits, they have been engineered in different ways.
First, the APS kit is about $1000 more expensive.
Second, the APS kit mounts the turbo down low, and not visible from the engine bay. Turbonetics chose to install theirs in the front of the engine bay, essentially where the factory airbox used to sit. APS maintains their design results in faster spool up, and more effecient turbo operation, among other benifits. The Turbonetics, from the dyno charts I've seen, seems pretty darn impressive in the midrange, and according to Mai, its generating 8psi of boost pressure in the mid 3000rpm range under heavy load.
Third, APS uses an Unichip for tuning. Turbonetics uses an ECU Reflash.
The APS single kit appears to be a very well engineered kit as well...as most of their products are. There are subtle differences between both kits.
Personally, I would have no reservations about installing either of these kits. It will be a month or so at least before the single T's arrive in the states, and the initial batch are all already presold to customers. So I would not expect to see inventory on the APS single kits until Aug or so.
You can also refer to Mia's other single T threads, as there are some lively debates about the FAB's of both kits. Good luck with your decision!
Old Jun 12, 2005 | 09:17 AM
  #46
nl12's Avatar
nl12
When can I buy this for my 2005 G35 coupe?
Old Jun 12, 2005 | 01:17 PM
  #47
georgiaboy's Avatar
georgiaboy
is this GB still going on?
Old Jun 12, 2005 | 03:04 PM
  #48
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
It's not a group buy. It's just special pricing.
Old Jun 13, 2005 | 12:05 PM
  #49
C-Lawd's Avatar
C-Lawd
That's a question I have as well. Is the Turbonetics ST available for the G35 Coupe?
Old Jun 13, 2005 | 12:26 PM
  #50
Sharif@Forged
Forged Performance
Not yet, although its coming shortly.
I bet Mia can jump in and advise.
Old Jun 13, 2005 | 12:27 PM
  #51
Sharif@Forged
Forged Performance
Pricing special is good until the end of the month.
Old Jun 14, 2005 | 07:30 AM
  #52
MIAPLAYA's Avatar
MIAPLAYA
The G35 kit is moving along. Brad's car is in the shop for it. The modifications to the kit were/are quick. There are some other added features that I'm sure that the G owners will appreciate that are being developed now...
Old Jun 14, 2005 | 12:29 PM
  #53
NissanJunkie's Avatar
NissanJunkie
[QUOTE=Sharif@Forged]The kit uses a reflashed ECU, QUOTE]
So do you get another ECU with the delivery of the Kit or do you have to send in your ECU????
Old Jun 14, 2005 | 12:31 PM
  #54
MIAPLAYA's Avatar
MIAPLAYA
[QUOTE=NissanJunkie]
You have to send in you ECU as each ECU is coded to a specific code stored on your actual key..
Old Jun 14, 2005 | 12:33 PM
  #55
NissanJunkie
well then how does that work when people have a Coded ECU and another Stock ECU???
Old Jun 14, 2005 | 12:39 PM
  #56
MIAPLAYA's Avatar
MIAPLAYA
I'm not sure what you mean. You pull your ECU out of the car and ship to Turbonetics before you begin the hardware install. It is sent bac reflashed within 3 days.
Old Jun 14, 2005 | 01:04 PM
  #57
Turbonetics's Avatar
Turbonetics
there are a couple of ways as I understand it. if you buy a new ECU the security feature that is VIN # specific has not yet been written to therefore when you plug in a new ECU the on board computer writes code that enable the use of this new ECU. if the ECU has already been written it will not work without some major work. Technosquare can do this work but it involves opening up the ECU and making changes internally...not excaly sure what but from what was explained to me it's not an easy mod.
Brad
Old Jun 14, 2005 | 01:07 PM
  #58
SirJonnyWispit's Avatar
SirJonnyWispit
FEDEX picked mine up around 5:30pm on a friday afternoon and i had it in my hands by 11:00am tuesday morning.... very quick moving of the ECU.
Old Jun 14, 2005 | 01:21 PM
  #59
Sharif@Forged
Forged Performance
The Turbonetics kit is being sold with the reflash included in the price. All you need to do, is remove your ECU and send it to Turbonetics. They will reflash and send back you. 3 day total turnaround time.
Old Jun 14, 2005 | 01:34 PM
  #60
kcobean's Avatar
kcobean
The ECU travel is really a non-issue. The shipping materials/label are included (as is the cost of the reflash, which is done by and at Turbonetics), and per the install manual, one of the first things you do (after the A/C purge/recharge) is remove the ECU and get it on the road. Unless you really whiz through the install, the ECU will be back before you really need it.
You gotta give T-netics props, this is a well thought out procedure.
