Vortech SC OR Turbonetics ST?
Old Jun 9, 2005 | 10:46 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Bubble
i bought the topspeed header last week. About to install it but someone mention that Turbonetics will not fit with TopSpeed header. So which aftermarket header will fit with Turbonetics?
taurran got the DC Sports headers to work on his. It took some "massaging" of the downpipe but it fit.
Gman2004's Avatar
Gman2004
Originally Posted by cloudy
+1
And how long does the Vortech SC take to install? That would be another factor i think compared to the 10-12hr install of the Tnetics ST.
vortech install is about the same time.
Old Jun 9, 2005 | 10:47 AM
Gman2004's Avatar
Gman2004
aren't the top speed replicas of the dc sport?
MIAPLAYA's Avatar
MIAPLAYA
+1
Not sure about the Vortech install. However Turbonetics recommends the stock plugs on their kit. I have had mine running with the stock plugs since January.
Old Jun 9, 2005 | 10:48 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Can someone confirm that? I was told that they were good. I need to know this ASAP.
I was quoted 13 hours for the Vortech install.
MIAPLAYA's Avatar
MIAPLAYA
No they are replicas of the Fujis. Its a tight fit so if possible I would compare the runners to see if they even have a prayer.
taurran's Avatar
taurran
It will fit with some adjustments, but we're still having some issues with it contacting the frame. Overall, I'd say if you're going with this kit, sell your headers and just install it using the stock manifolds. Your install will just be that much easier and cleaner if you use the stockers.
Old Jun 9, 2005 | 10:49 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
DC sport is the same as TopSpeed. MIAPLAYA, which header did you use?
MIAPLAYA's Avatar
MIAPLAYA
Theres not really a way to confirm them unless you can look at a DC Sports header side by side and see if the primaries are wider on the Topspeed headers.
MIAPLAYA's Avatar
MIAPLAYA
I am running the stock headers personally. Making 380 RWHP
Old Jun 9, 2005 | 10:51 AM
Gman2004's Avatar
Gman2004
That's about right. When I was getting my vortech installed I got anywhere from 8-12 hours for the install. I would try to negotiate a little.
Old Jun 9, 2005 | 10:52 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
installation cost for Vortech run from $1000 to $1400. That is what i was quoted at.
Old Jun 9, 2005 | 10:55 AM
Phatmitzu's Avatar
Phatmitzu
...However Turbonetics recommends the stock plugs on their kit...
Why is that?
I've already bought the colder plugs...
Bubble's Avatar
Bubble
-REPLICA ARMY-
those of you have Turbonetics ST installed, would it be possible if you can post the sound clip of it?
Old Jun 9, 2005 | 10:56 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Thanks. I had an install of the headers and Clutch/flywheel scheduled for next weekend - was planning on Vortech now Im not sure. Trying to decide if I should still install the headers or not. AAM said they would be a good complement to the system and if I go Vortech it makes sense. I am a little worried about them though if I go with the TNetics kit both from a fitment and a heat viewpoint.
Old Jun 9, 2005 | 10:58 AM
taurran's Avatar
taurran
Heat shoudn't be an issue. It's more of a fitment issue than anything.
If you're going Turbonetics, keep with stock headers if possible as it will make your life much easier during and after install.
With the Vortech, headers should be no problem.
I'd say sell your headers and use the cash to grab the Turbonetics kit.
Old Jun 9, 2005 | 11:00 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Phatmitzu
Why is that?
It shouldn't be a problem to run colder plugs. I believe taurran is doing so now. However all testing was done on the stocker plugs.
Old Jun 9, 2005 | 11:02 AM
  #38
taurran's Avatar
taurran
I'm going to hopefully have some videos up this weekend of my kit running. Most likely Saturday.
I took mine in today for some adjustments, and ran it by the shop a few times. My installer said "it sounds like a turbo'd RB26". I consider this a good thing.
I'm running the Fujitsubo Legalis-R exhaust with it, and it sounds sweet.
  #39
MIAPLAYA's Avatar
MIAPLAYA
Check this thread.
https://my350z.com/forum/showthread....highlight=pics
There are like 4 videos go through all the pages.. only 3 of them...
Old Jun 9, 2005 | 11:03 AM
  #40
MIAPLAYA's Avatar
MIAPLAYA
Like taurran said they should be fine but you aren't going to get too much power gain from it. Maybe a few horse. At 380 RWHP the money you are going to spend to get a few more horse may not be worthwhile.
