variable boost question
Old Jun 11, 2005 | 07:46 PM
04z33kid's Avatar
04z33kid
Default variable boost question
if i got lets say the aps tt kit or any kit that can spin the wheels in 1-3 gear, with a stock motor, would it be possible to lower the boost for gear 1 then up it a little for gear 2, so this way the wheels wont spin as much. so like in 5th gear it is higher so it feels like there is always more power?
is this possible or would you have to go with another managment system besides the one they send you with the kit and an extra boost controler?
thanks
Old Jun 11, 2005 | 09:15 PM
g356gear's Avatar
g356gear
You might be able to use a boost scrambler like the ones Turbo XS makes. They bleed off boost in the first couple of gears for increased traction....if I remember correctly.
Old Jun 11, 2005 | 09:45 PM
UnderPressure's Avatar
UnderPressure
There are boost controllers available that limit boost depending upon wheel speed. I think the profec-b is boost vs wheel speed capable.
Old Jun 12, 2005 | 06:49 AM
al_v's Avatar
al_v
If you have to do that you need the Apexi AVC-R boost controller,is the only one that have the option to make differents boost levels for any gear.
Old Jun 12, 2005 | 08:19 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Many boost controllers can adjust solenoid duty cycle by RPM, very few are gear depenedant. I still havent found one. I believe the HKS is RPM dependent....as is the e-01 and Spec B
Old Jun 12, 2005 | 11:13 AM
04z33kid's Avatar
04z33kid
ok so if i have the aps tt kit and the e-01 will his mess anything up with their ecu they send?
issyz
Jul 2, 2017 03:04 PM
