Turbonetics S/T Trap Speed???
Has anyone ran there Turbonetics S/T car at the track yet? If so what was the trap speed. I had a Vortech that I sold a few months ago and I only had a 109 - 110 trap speed. I was putting down 376 RWHP. I am wondering if I can get my car in the 113 -116 mph with this kit. Thanks for all the help.
Well i should see no problem with trapping in the 113-116 range. The turbonetics kit will probably produce very similar numbers as ur vortech, but it will also hit full boost a lot quicker. So instead of hitting 8psi at redline, you'll probably hit it at like 4k. Vortech and Procharged Z's seem to vary in trap speeds. Ive seen some Z's trapping 106 and some trapping 112-113. I dunno if its the driver or what, but the one guy who trapped 112.9, did it with an automatic tranny.
I have the money for the built motor now I need more money for the S/T kit and the labor. Hey Mia, what kind of power you think the stock turbo can put to the ground with the built motor. I should have a built Single turbo 350z by this winter. I want it now!!!
Originally Posted by Laww
Hey Mia,
Update to that ET for the 350Z....at Capitol Raceway on 9/30 I recorded a 12.4 @ 113.95
Laww
Laww
Well due to the fact that they are street tires I can't launch very high...right around 2400rpms is about the most I can do and still maintain enough traction to get out of the hole. I have to shift again at around 5500rpms to maintain traction between first and second...but after that it's ***** to the wall and I am getting to the end of the run bumping up against 7000rpm range as I cross the 1320 mark in fourth gear.
Laww
Laww
Just ran my at the 1/4 trap is 112.7 ET is 12.8. Last time I went, I ran 12.8 at 109 mph. My 60' time was 2.0 to 2.1, wondering why my trap went up but my ET still the same
maybe it's my shifting. I hate it when almost crossing the finished line...i'm in 4th gear and reaching the rev limiter. This is on 18' toyo tires.
This is really weired... all of the turbonetics 1/4 times on these forums are pretty low. Not to be bragging or anything but i noticed alot of N/A Z's running 12.8-13.1 on just simple blot ons. I ran a 12.8 on the street with all of my mods except the turbo kit and at the track i ran a 13.11 on T/A KD tires. Is it just the difference of drivers? or maybe every car is really different.
Those are nice times for being NA too though!
12.8 Someone really had a good run that day with simple mods
If I could hook up and / or launch more aggressively there is no doubt in my mind I could shave another 2 to 3 tenths off at least. I will be testing this theory soon when I get a set of drag radials. All of my times so far are just the way I drive it every day...nothing special done at the track except drive up and launch. No tire pressure gauge checking my back tires, no smoky burn outs at the line (strret tires are pricey these days), just stage and launch....
Laww
Laww
