Greddy TT eManage Base Map
Sorry if this has been posted in a previous thread...
I just purchased the Greddy TT Kit for my 05 350Z with the e-01 Boost Controller. Thanks to Sharif @ Forged Internals!! Very knowledgable with this system and was the only person that I contacted that returned messages in a timely fashion. I would reccomend his business to anyone out there who is looking to boost their VQ...
Having owned my own speed shop a couple of years ago, he was very honest and upfront with any information that he discussed with me. That is a hard thing to find these days in this industry!
I would like to to a retune of the eManage for a MAP based tune instead of the MAF tune along with the ignition timing... It is my understanding that once you try to access the eManage the preset program that is in it will be erased and cannot be copied over. Does anyone have a base tune that I can get started with that will be close to the following setup?
MAP tune @ about 7psi
255 Fuel Pump (no return fuel system yet...)
Ign timing retard
Cat-Back Exhaust
Stock Cats still installed
Honestly if anyone has anything close to this it would be of tremendous help. It is better than starting from scratch. I realize that I need to get on the dyno and tune specificaly to my car, but a base map should get me close.
Thanks in advance to anyone that can provide this info to me.
Having owned my own speed shop a couple of years ago, he was very honest and upfront with any information that he discussed with me. That is a hard thing to find these days in this industry!I would like to to a retune of the eManage for a MAP based tune instead of the MAF tune along with the ignition timing... It is my understanding that once you try to access the eManage the preset program that is in it will be erased and cannot be copied over. Does anyone have a base tune that I can get started with that will be close to the following setup?
Ign timing retard
Cat-Back Exhaust
Thanks Joe...your kit is going to arrive on time on Friday!
As we discussed, I have a bunch of pressure based maps to get your started, but they require a return fuel system. I also have a base map for about 6-7psi with just a Walbro 255 that is MAF tuned, rather than pressure.
Hopefully someone else will have that pressure map, that will work with your setup. And don't foget to call me on the weekend, and I will give you some installation pointers. Thanks again for the business.
