Turbonetics ST Dynoed & A/F graphs!
Old Jul 29, 2005 | 07:42 AM
Z PHAT Z's Avatar
Z PHAT Z
Default Turbonetics ST Dynoed & A/F graphs!
Alright guys! Here they are. Here are my mods with the T-netics:
UR pulley
Crawford plenum
Stillen headers
Ground wire kit
I'm running with OEM exhaust for now. Fabing the Borla TD sometimes soon.
Let me know what you guys think about the A/F and power. Thanks.
Old Jul 29, 2005 | 07:44 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Decent numbers for that kind of dyno, although Ive seen similar on a dyno like that on a pretty much stock car.
Edit-got the psi and a/f's confused. Your making less than the base 8psi, and your a/f's although not "smooth" are pretty safe...why is yor yellow line dyno so much leaner around 5000rpm's? Do you plan on fine tuning it some to your mods?
Old Jul 29, 2005 | 07:47 AM
RBlover69's Avatar
RBlover69
dude where the hell is amherst i need to see this
Old Jul 29, 2005 | 07:54 AM
Z PHAT Z's Avatar
Z PHAT Z
I'm making 7.5 PSI max. Everything seems to work fine, but don't know why I didn't make full 8 PSI. The yellow line is the first pull and it reads kinda richer than the second pull, again don't know why . I will have to find something to fine tune my car, maybe E Ultimate.
Old Jul 29, 2005 | 07:55 AM
Z PHAT Z's Avatar
Z PHAT Z
It's near Buffalo, New York. About 6 hours drive from your place Come down here and I will give you a test drive.
Old Jul 29, 2005 | 10:34 AM
Phatmitzu's Avatar
Phatmitzu
Good deal.
The A/F looks safe, but as Alberto pointed out, its pretty all over the place. You might want to consider a piggyback and have it fine tuned on Dyno. More HP shall be seen.
BTW,
How was the install with the Stillen headers? Any modification? any rubbing?
I will be installing my ST with the current Nismo headers...hopefully I wont have any fitment problems.
Old Jul 29, 2005 | 11:09 AM
Z PHAT Z's Avatar
Z PHAT Z
Originally Posted by Phatmitzu
Good deal.
BTW,
My installer told me that there is no modification to fit the headers in. As for rubbing, I have to get under the car to check it out after maybe a week to see if there is any sign of scratch.
Old Jul 29, 2005 | 11:13 AM
JeffesonM's Avatar
JeffesonM
so "full" boost right around 4000 RPM? how's it feel?
Old Jul 29, 2005 | 11:17 AM
Z PHAT Z's Avatar
Z PHAT Z
OH BOY! How can I describe theis?? hmmm....First time I hit it...it gave me goose bump I was like WOW ..WOW....sh1ttttt!!!!!!!
jlimquest's Avatar
jlimquest
I thought headers were not recommended w/ the Turbonetics ST? Also, I noticed that you kept the UR pulley. Is that OK too? Thanks!
Old Jul 29, 2005 | 11:22 AM
taurran's Avatar
taurran
Lookin good. I'd love to get a Turbonetics kit with the stock manifolds on this same dyno to see if it spools up much sooner. As said before, the wider diameter of the aftermarket headers is most likely causing the exhaust gasses to move at a slower velocity, thus making spool up time slower.
As far as the AF, I'm not sure why you'd be running so rich. Hmm.. I really wish we could get someone with a totally stock ST kit on this to compare.
Old Jul 29, 2005 | 11:24 AM
Alberto's Avatar
Alberto
Cranky FI Owner
CP should be fine with this kit. I think I might keep mine on when it arrives. And you can run aftermarket headers, but they arent as strong as the stock units, and shouldnt be able to withstand so much heat for as long, but only time will tell, its not like they would crack after a few days or anything. I personally wouldnt run aftermarket headers on this kit, all the dyno's with headers seem to be just as high if not lower for some reason than the stock ones. Its at least fair to say that there has been no eveidence to suggest aftermarket headers are making power on this kit, with the stock tune.
Old Jul 29, 2005 | 11:49 AM
JeffesonM's Avatar
JeffesonM
that would make sense... I thought most of the other turbonetics installs were getting full boost earlier in the RPM range
Old Jul 29, 2005 | 11:56 AM
Z PHAT Z's Avatar
Z PHAT Z
Allright! I will spend some money to take off the after market headers and put the stocks back on and re-dyno. Anyone would like to chip in ?
Old Jul 29, 2005 | 12:12 PM
Peking's Avatar
Peking
Seems just like mine, dipping into the 10's for A/F. But hopefully with the Emanage Ultimate we shall fix that
Old Jul 29, 2005 | 01:14 PM
taurran's Avatar
taurran
I'm doing the same this fall. I'll definitely be posting before/after graphs. I'm going to be jet hot coating the stockers, and also header wrapping as much piping as possible whilst its broken down.
Old Jul 29, 2005 | 02:22 PM
Phatmitzu's Avatar
Phatmitzu
Lookin good. I'd love to get a Turbonetics kit with the stock manifolds on this same dyno to see if it spools up much sooner. As said before, the wider diameter of the aftermarket headers is most likely causing the exhaust gasses to move at a slower velocity, thus making spool up time slower...
True. But I would suspect high-end hp will suffer?
I would like to see stock vs aftermarket header on the same dyno as well.
Old Jul 29, 2005 | 08:10 PM
taurran's Avatar
taurran
Possibly. However, I'm hitting lower top end hp on the dyno right now than others running stock manifolds. I'm guessing the stock manifolds with jet hot coating will give me some great gains both hp wise and boost threshold wise.
Old Jul 29, 2005 | 08:12 PM
taurran's Avatar
taurran
Oh, and I really like those dyno dynamics graphs. I might see if anyone around here has one and get some runs in. I'm mostly interested in that AF/Boost graph.
Old Jul 30, 2005 | 05:19 AM
MardiGrasMax's Avatar
MardiGrasMax
If you plan on turning up the boost keep the headers on their.
