Turbonetics G35 kits in/installs in progress
Old Aug 14, 2005 | 10:28 AM
  #41
SpeedDreamTuner's Avatar
SpeedDreamTuner
We don't have the official instructions for G's yet although with the exception if the intake and A/C lines, they should be the same so I can't comment on that.
On one car we set it up just like the normal Z kit, however what I think happened is that the blowoff valve instructions were included and they instruct a different installation than the kit.
IIRC, the compressor goes to the wastegate, then a vacuum line off the manifold goes to the top of the valve in the kit? Is that right MIA?
Old Aug 14, 2005 | 10:34 AM
  #42
SpeedDreamTuner
http://www.turboneticsinc.com/downlo...ypassValve.pdf
They claim to use the boost sensing port in that. They claim to have quicker response when connected. Six to one, half a dozen the other....
Old Aug 14, 2005 | 10:45 AM
  #43
MIAPLAYA's Avatar
MIAPLAYA
I think you are supposed to go off of the kit instructions and disregard the BOV ones...On my kit the pressure line goes from the plenum to the top port of the BOV. and from the compressor to the bottom port of the wategate...
Old Aug 14, 2005 | 02:08 PM
  #44
35ounces's Avatar
35ounces
03 CS Track 6MT
I think thats right and problem where the confusion came in (the BOV instructions).
hey I have another question regarding the install. I vaguely remember that some people had issue with the MAF wires hitting the plenum or being squeezed in there. Mine is like that also. Did you have to change it so that the MAF is pointing outwards or is it inwards on your install?
Thanks in advance.
I dont know if you can see it in this pic or not...
Old Aug 14, 2005 | 02:11 PM
  #45
MIAPLAYA's Avatar
MIAPLAYA
Thanks in advance.
Mine is pointing inwards and it is close but it doesn't ever hit the plenum....
Pic:
That pipe is secured to the block and moves WITH the motor not independent of it so it never gets any closer then that to the plenum...
Old Aug 14, 2005 | 03:01 PM
  #46
SpeedDreamTuner
I agree with MIA on the MAF thing. Although, we install SSV's on all of our Turbonetics cars so I don't think we've run into that problem.
As far as the BOV thing, both of our cars run great and perform identical, so I honestly can't say it's a problem at this point.
Old Aug 14, 2005 | 03:03 PM
  #47
MIAPLAYA's Avatar
MIAPLAYA
Oh no its not a problem...just make sure that the compressor signal tees off to the lower wastegate port also or be prepared for some nice boost increases I honestly dont know what attaching the line to the middle port AND upper port would do though...
Old Aug 14, 2005 | 03:06 PM
  #48
SpeedDreamTuner
Ya thats what we did exactly, tee'd the compressor, one to the wastegate, one to that lower valve. To be honest, the BOV seems a bit more controlled with it attached. Our shop car makes that 'DO do DO DO do dooot' sound where this car doesn't make so flutterly if that makes any sense.
Old Aug 14, 2005 | 03:08 PM
  #49
MIAPLAYA's Avatar
MIAPLAYA
It does actually....
Old Aug 15, 2005 | 02:13 PM
  #50
g356gear's Avatar
g356gear
So what extra parts are actually different with the G35 kit over the 350Z kit?? I understand that the fans are different but what else?
Old Aug 15, 2005 | 02:18 PM
  #51
MIAPLAYA's Avatar
MIAPLAYA
The compressor inlet pipe is different. Some of the intercooler piping is different. Mainly from the compressor discharge to the intercooler inlet. I believe one of the exhaust pipes is different specifically I think it was the crossover pipe but I could be wrong there. Of course as you said the fans and shroud. There is an extra relay in this kit that connects to a pre-determined specified source for fan power. The relay is a boost activated one so there is a boost signal line from the plenum I believe to switch the fan voltage from 6 to 12 volts under boost. I think thats it. The intercooler piping from the outlet to the throttle body I think is the same. Intercooler, turbo, wastegate, and BOV are all the same.
Old Aug 16, 2005 | 10:24 PM
  #52
Speed Dreams's Avatar
Speed Dreams
You summed it up nicely.
Old Aug 17, 2005 | 08:17 AM
  #53
MIAPLAYA's Avatar
MIAPLAYA
Thank you....
Old Aug 17, 2005 | 09:09 AM
  #54
LaPuLaPu's Avatar
LaPuLaPu
SpeedDreams, how are you achieving 12lbs of boost with the stock Turbonetics kit? Would you mind sharing your dyno sheet with the rest of us? I’d like to check-out your A/F.
Old Aug 17, 2005 | 09:44 PM
  #55
Speed Dreams
We were shimming the waste gate spring to hold more pressure. Our shop car always comes last for work or parts. We didn't have a boost control in stock so that's what we had to resort to.
When I have a free minute I will scan a dyno of the shop Z and post.
Old Sep 3, 2005 | 11:31 AM
  #56
g356gear's Avatar
g356gear
Any updates on the release date for the G35 kit??
Old Sep 3, 2005 | 10:54 PM
  #57
Speed Dreams
The kit should be out this month.
Old Sep 4, 2005 | 09:58 AM
  #58
SpeedDreamTuner
Just wanted to give everyone an update. The G35 kit yesterday after ever so minute adjustments made 440/460 @ 12 PSI. We went from 7 PSI, all the way up to 12 and the A/F was the exact, and I mean exact same.
Old Sep 4, 2005 | 12:37 PM
  #59
MIAPLAYA's Avatar
MIAPLAYA
GREAT numbers bro...CONGRATS!!!
Old Sep 5, 2005 | 09:46 AM
  #60
escobar929's Avatar
escobar929
how safe is this kit, will it be as safe and reliable as a vortech?
