Turbonetics G35 kits in/installs in progress
Old Sep 5, 2005 | 09:50 AM
  #61
35ounces's Avatar
35ounces
03 CS Track 6MT
who's car is that with the TNetics kit and the SSV? Can we get some finished pics of the engine bay please
Also, what effect on A/F did the SSV have if any?
Old Sep 5, 2005 | 09:41 PM
  #62
Speed Dreams's Avatar
Speed Dreams
which are you referring too, we did three in the last two weeks. This 04 pictured will be in Sport Z magazines next issue.
We didn't do a before and after on the plenum but a/f was normal for the kit. We also took another G with the kit to 12lbs with no a/f change..that surprised me.
Attached Thumbnails Turbonetics G35 kits in/installs in progress-p1010036.jpg   Turbonetics G35 kits in/installs in progress-p1010039.jpg
Old Sep 5, 2005 | 11:08 PM
  #63
BRING IT's Avatar
BRING IT
How safe is it @12lbs for a everyday driver?
Old Sep 6, 2005 | 01:26 AM
  #64
accordfreak's Avatar
accordfreak
were you able to get pictures of the OEM A/C lines side by side with the turbonetics one?
Old Sep 6, 2005 | 06:42 AM
  #65
taurran's Avatar
taurran
Did the SSV make any more power with the ST? So far I've been waiting on hearing the results but have yet to see any.
Old Sep 6, 2005 | 06:50 AM
  #66
35ounces's Avatar
35ounces
03 CS Track 6MT
+1
Old Sep 6, 2005 | 06:52 AM
  #67
35ounces's Avatar
35ounces
03 CS Track 6MT
I am also interested in which exhausts you are all using. I'm not crazy about how my NISMO exhaust sounds now with this kit installed. It used to sound sweet now it just sort of grunts and never gets to the sweet notes.
Old Sep 6, 2005 | 04:24 PM
  #68
SpeedDreamTuner's Avatar
SpeedDreamTuner
Oh ya
Old Sep 9, 2005 | 11:15 AM
  #69
bwzabodyn's Avatar
bwzabodyn
+2 on the exhaust question...
Old Sep 9, 2005 | 02:23 PM
  #70
jruss9819's Avatar
jruss9819
Tanabe Super Medalion Hyper was the exhaust we went with. It sounds way different from the Injen that I came from. It's much more quite. It does look like an excellent exhaust system and bolted right up with the turbo.
Old Sep 9, 2005 | 04:47 PM
  #71
accordfreak
did you get the picture?
Old Sep 9, 2005 | 11:35 PM
  #72
Speed Dreams
Where I live at 5,200ft we're fine,420whp sae corrected equates to about 368 corrected for our altitude with the TN tune a/f running 11.8 wot. Way below the rod danger zone.
Old Sep 9, 2005 | 11:45 PM
  #73
Speed Dreams
No and there is two takes on this a/c line issue. One G we ran the stock line under the turbo and back for a clean look, this failed due to heat from turbo down pipe. The other we ran the oem line to the left side top of the turbo and have had no problems. This can be tricky b
ut when the TN G kit is available it will include an a/c that is about 4" longer and take away the guess work.
Old Sep 9, 2005 | 11:50 PM
  #74
Speed Dreams
About 20-25whp with standard TN reflash,more if you tune for plenum as we have seen.
This calculation is based on a comparison to our shop Z with stock plenum and power data at various boost levels.
You got a PM......
Old Sep 10, 2005 | 05:55 AM
  #75
35ounces's Avatar
35ounces
03 CS Track 6MT
so the TNetics standard flash was fine with the SSV? Did not lean out?
Old Sep 10, 2005 | 06:17 PM
  #76
SpeedDreamTuner
Nope
Old Sep 10, 2005 | 07:32 PM
  #77
nissansource's Avatar
nissansource
thats great news.. and you said the af ratios stayed the same at that 12psi boost level
Old Sep 10, 2005 | 07:58 PM
  #78
accordfreak
hmm that's interesting. thanks for the reply. so you had to bend the oem hard line in order to make room for the downpipe?
in the picture below, did you bent both sides that's circled in yellow? if so, how was it bent? top one bent to the left and the bottom one bent upwards?
thanks for your help!
Old Sep 10, 2005 | 08:43 PM
  #79
AmyCroft's Avatar
AmyCroft
Default Insulation of Turbo
Insulation of Turbo
I hope you guy's are putting an Insulation Blanket on theose turbo's. Ya gota have AC...
Cheers Amy -
Old Sep 10, 2005 | 09:19 PM
  #80
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by AmyCroft
Insulation of Turbo
Cheers Amy -
Yes sir...hte kit comes with a heat shield for the turbine side of the turbo...
