Turbonetics ST Feedback
Old Aug 17, 2005 | 10:07 AM
  #61
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by davidahn
Thanks, MiaPlaya. I think I could be happy with 390 to the wheels, but like I said, 400 is such a nice round number.
What would the T66 do, and what would it cost?
David
I would need to ask Brad about the cost of doing that as well as how they would do the setup for you..I'll try to get a hold of him today and see what he says..
Old Aug 17, 2005 | 01:48 PM
  #62
Peking's Avatar
Peking
MIA did you say they are working on a drop in fuel injector upgrade?
Also for those of you who do want to use a lower boost setting, I would just suggest ordering a weaker spring for the wastegate (which you can). Then I think if you want to use a Technosquare flash then you need to give them a A/F reading for them to use or get a piggy back management like the Emanage Ultimate then get tunned...
So I say get the Tuner Kit Version (cheaper tech, but you will still need to get injectors and fuel pump to still be safe with the fuel), lower strength spring for the wastegate, and either a flash or other means for managment
Old Aug 17, 2005 | 01:50 PM
  #63
MIAPLAYA's Avatar
MIAPLAYA
Yes they are...it would be drop in 550cc injectors and a flash..
Old Aug 17, 2005 | 01:53 PM
  #64
Peking's Avatar
Peking
Hmmm... I might just buy the injectors cause by then I shouldn't need a flash
But once again another option, other kits don't offer so many choices
Old Aug 17, 2005 | 02:03 PM
  #65
MIAPLAYA's Avatar
MIAPLAYA
That would work too....
Old Aug 18, 2005 | 09:36 AM
  #66
MardiGrasMax's Avatar
MardiGrasMax
What do you guys think about a GT35/40R or GT40R with the T4 mounting flange. I have a single 60-1 at 16.5psi in my built 3.5L in my Maxima and she is running out of steam.
Old Aug 18, 2005 | 09:39 AM
  #67
MIAPLAYA's Avatar
MIAPLAYA
What size is your downpipe? Just curious....a T70 should get you some significant head room to work with...
Old Aug 18, 2005 | 10:55 AM
  #68
350Zteve's Avatar
350Zteve
This is a great thread. Always good to hear from the end users. Does anyone know if TN does installs on their kit?
Old Aug 18, 2005 | 10:59 AM
  #69
MIAPLAYA's Avatar
MIAPLAYA
No they don't do intalls at their shop. With all the fabrication and production going on there, there just isn't any room. You should come check out the Open House they are having on Sept 24.
Old Aug 18, 2005 | 01:16 PM
  #70
davidahn's Avatar
davidahn
Where's that open house gonna be? And what are these weekly meets you guys are talking about in San Diego? I'd like to show up and see some of the monster Z's you guys have.
David
Old Aug 18, 2005 | 01:23 PM
  #71
2JZfan's Avatar
2JZfan
how much power are you trying to make and at what boost level?
Old Aug 18, 2005 | 01:32 PM
  #72
MIAPLAYA's Avatar
MIAPLAYA
David
The open house is gonna be at Turbonetics in Simi Valley..check the Socal forum for the sign up list...the weekly meets are on Clairmont Mesa blvd every Tues night with other Evos, WRXs, Supras, whatever really...good time//
Old Aug 18, 2005 | 01:48 PM
  #73
MardiGrasMax
3" downpipe, full 3" exhaust.
I have 740cc injectors so I'm good for fuel to ~700hp.
Old Aug 18, 2005 | 02:04 PM
  #74
MIAPLAYA's Avatar
MIAPLAYA
Then a T70 sounds like its in your future....
Old Aug 18, 2005 | 02:07 PM
  #75
MIAPLAYA's Avatar
MIAPLAYA
Link to Turbonetics Open House Thread: https://my350z.com/forum/showthread....1643342&conly=
Old Aug 18, 2005 | 02:35 PM
  #76
davidahn's Avatar
davidahn
Thanks, MiaPlaya.
David
Old Aug 27, 2005 | 03:33 PM
  #77
z327's Avatar
z327
Yes they do...the 5AT kit is shipping now I believe....
It is not available for the 5AT.
The crossover pipe does not exist yet. I had to have one custom fabricated.
The transmission cooler lines (metal) have to be cut and longer hoses used to clear the pipe that goes down across the front of the engine.
You will needs lots of extra heat protective material for the transmission cooler lines and your O2 sensor wiring. They won't fit in the down pipe due to clearance issues with the 5AT housing.
I got the kit with the cat so I had to lengthen the wiring to the O2 sensors which go into the Cat on either side if the drive shaft.
Be sure and add extra heat protection to both AC hoses as well. What Turbonetics provides is not enough IMHO.
Old Aug 31, 2005 | 06:03 PM
  #78
DXB350Z's Avatar
DXB350Z
sorry if this has been asked before..but will this kit work with stock exhaust without being modified?
are the injectors and fuel supply drop in?
what about the oil pan? does one need to purchase that seprately? i noticed its not included in the kit..
thanks..
Old Aug 31, 2005 | 06:06 PM
  #79
kcobean's Avatar
kcobean
thanks..
Yes, this kit was designed with the stock exhaust in place.
Injectors are drop in. Pump is drop in, but the regulator requires minor modification.
oil pan is stock, no need to replace it. The oil line taps into the side of the upper pan, though you could tap a pan spacer if you wanted to.
Old Aug 31, 2005 | 06:34 PM
  #80
DXB350Z's Avatar
DXB350Z
thanks kcobean...could you just be alil more precise..what kind of modificatoin would the regulator require?
btw...B U T FUL ride you got there..
