Getting CEL, Error codes inside
Old Aug 16, 2005 | 05:45 PM
backagain's Avatar
backagain
Default Getting CEL, Error codes inside
Hooked up a wideband gauge today, innovative motorsports, did not tap into ecu or anything, simple power and ground. got the codes checked at advance auto parts. here they are.
any ideas ?
P0031
HO2S Bank 1 Sen 1
Heater Circuit
Low
P0051
HO2S Bank 2 Sen 1
P0037
HO2S Bank 1 Sen 2
Heater Circuit
Low
P0057
HO2S Bank 2 Sen 2
Heater Circuit Low
Old Aug 16, 2005 | 05:52 PM
theking's Avatar
theking
You hooked up a wideband gauge and O2 sensor? Sounds like you hooked up the gauge to the stock sensor but hooked it up the heater ground(common) lead. I'm a bit confused please explain how you hooked it up.
any ideas ?
P0031
HO2S Bank 1 Sen 1
Heater Circuit
Low
P0051
HO2S Bank 2 Sen 1
P0037
HO2S Bank 1 Sen 2
Heater Circuit
Low
P0057
HO2S Bank 2 Sen 2
Heater Circuit Low
Old Aug 16, 2005 | 06:08 PM
backagain's Avatar
backagain
hooked it up to it's own bung, didn't tap into any stock wires or sensors,
Old Aug 16, 2005 | 06:10 PM
theking's Avatar
theking
this makes absolutely no sense then. where did you tap for power and ground then. it almost looks like you tapped one of the stock(or both) stock sensors for power and ground.
If you hooked it up the way you said you did then it is a system totally independent of the stock system other than the fact it gets power from the battery and ground from the chassis ground. there must be more to this. did you turn up the boost, down, etc?
Old Aug 16, 2005 | 06:17 PM
phunk's Avatar
phunk
CJ Motorsports
if you had the stock o2 sensors unplugged for some reason while working on you car, but you turned your key on for some other reason.. this would cause those codes. are you sure they are not there from servicing your car with the key on?
Old Aug 16, 2005 | 07:01 PM
backagain's Avatar
backagain
phunk, not sure what you mean by servicing my car with the key on.
theking, i did not tap the stock sensors or anything, ground from 12v power sorce inside the car and ground to chasis, i did get a new supercharger belt put on this weekend and had the car tuned, but im sure that has nothing to do with my codes. i did have a narrow band gauge hooked up for a few weeks, taped into the wire under the MAF. that was taken out today as well. possible a wire hit something and fried the stock 02? thanks
Old Aug 16, 2005 | 07:08 PM
theking's Avatar
theking
I agree. Clear the codes and something tells me they won't come back.
Old Aug 16, 2005 | 07:21 PM
backagain's Avatar
backagain
i did, they came back.
Old Aug 16, 2005 | 08:08 PM
backagain's Avatar
backagain
on a side note, should the car be safe to drive hard with the stock o2 sensors like this ? does this have anything to do with the ss box from my vortech ? or should i take it easy until they are replaced if that is what needs to be done. thanks.
Old Aug 17, 2005 | 11:58 PM
leatherface_ca's Avatar
leatherface_ca
Default Please help me out 2.........
I had a malfunctioned passenger side O2 sensor for 4 months. Today I replaced it with a used O2 Sensor but the SES light is still on after resetting the ECU. I got the same code P0037, "HO2S Bank 1 Sen 2 Heater Circuit Low". Does that mean I fried my O2 sensor fuse? Fried the wiring? Or is it because the used O2 sensor is malfunctioning also?
By the way I have the SAFC-2 and the setting is kinda to the rich-side, could that be too rich? Anyone has any ideas? Please help out, thanks.
Old Aug 18, 2005 | 06:04 AM
theking's Avatar
theking
The code you get for richness in these cars is something along the lines of O2 sensor high voltage bank _. When I started to tune I made these tables that added alot of duty cycle. I started a little too rich and got these codes.
Alan
Old Aug 18, 2005 | 12:34 PM
leatherface_ca
So should I tune my car to make it run leaner?? Wut did you do? Thanks.
Alan
Old Aug 18, 2005 | 02:26 PM
theking's Avatar
theking
No please do not lean out your car because of what I said. I was giving an illustration of the codes that you get when you get the car extremely rich. These aren't the codes you or this guy are getting. These O2 sensors read close to 1v rich and close to 0V lean. These are also heated O2 sensors and these codes related to the heat circuit.(FYI-most widebands are not heated and that's why on first startup they take awhile to read anything but stoichor 14.7)
Old Aug 18, 2005 | 11:11 PM
leatherface_ca
um....................
Old Dec 2, 2005 | 11:39 AM
TakeiteZ's Avatar
TakeiteZ
sorry to bring this back from the dead... but im having the same issue... any news on what you guys did to get rid of it?
my car is not even supercharged, I just have test pipes... but my CEL just wont go away, i've reset it like 5 times...
Old Dec 2, 2005 | 02:34 PM
Fairlady_z33's Avatar
Fairlady_z33
i have this problem but mine is p420 and p430 its a catalytic efficency threshold thats what the obd 2 scanner came up with i had it twice already it always comes back when i drive the car hard. But also when i downshift in manual mode (automatic) it puffs smoke out and then it goes away but doesnt totally disappear i think is the test pipes what do you guys think it is. The car completely stock.
Any suggestions?
Old Dec 3, 2005 | 07:20 AM
TakeiteZ's Avatar
TakeiteZ
ttt... would putting the stock cats back on get rid of the problem? or do the sensors need to be replaced?
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
