The next mod I should get is...
Old Aug 18, 2005 | 02:45 PM
spdkils's Avatar
spdkils
Lightbulb The next mod I should get is...
Okay I've installed a lot of stereo, I've installed the APS turbos, and I've added after market TC. My next "speed" mod should be...
Old Aug 18, 2005 | 02:48 PM
sentry65's Avatar
sentry65
the burninator
APS TT isn't fast enough?
Old Aug 18, 2005 | 02:52 PM
spdkils's Avatar
spdkils
There is never enough speed...
I went from 5.5 0-60 to 4.7ish... I need to get 4.0 to beat my friends Z06. So taller gears, maybe cats, maybe plenumum, something... I have to get FASTERRRR.
(I need better traction... That is for sure! I cap out @ .77G, he can hit .88G)
Old Aug 18, 2005 | 02:53 PM
sentry65's Avatar
sentry65
the burninator
traction is a big issue on this car, get some drag radials if you want traction. That's really about the only way on a TT setup
Old Aug 18, 2005 | 03:02 PM
taurran's Avatar
taurran
Clutch/Flywheel, Cams, Radiator/oil cooler....
Hmm depends on what you've got and what you're aiming for.
If you're wanting to run the 1/4 then some new rubber sounds like a good idea.
Old Aug 18, 2005 | 03:39 PM
zimbo's Avatar
zimbo
Aftermarket LSD.
--Steve
Old Aug 18, 2005 | 05:18 PM
theking's Avatar
theking
Drag radials, then a clutch/flywheel, Radiator, LSD
Old Aug 19, 2005 | 11:18 AM
barthelb's Avatar
barthelb
Master
Has anyone proven or know for sure that the stock LSD needs to be improved. How would one tell
Old Aug 19, 2005 | 11:54 AM
failsafe306's Avatar
failsafe306
Can't answer that, but in this case I believe spdkils has a base model without LSD.
Old Aug 19, 2005 | 01:51 PM
spdkils's Avatar
spdkils
You are correct sir... No LSD here...
Well thats not true... I have a Quaife I use as a paperweight until Quaife can get the "spacer" figured out. (Another month out for that yeah?)
I started to look at wheels, then I found more information about back pressure causing the turbos to pitter out of boost @ higher RPMs, so I started to look for cat back systems.
Then I thought about getting it tuned... but I need to have my exhaust done before that...
So @ this point I'm going to drive it for another week until my favorite shops dyno is back online. Once I know my A/F and have more information about the Quaife I'll make a more informed choice. (Lean it out by reducing back pressure? Just do the Quaife? Get a tune with my current exhaust system?)
Anyway back to LSDs, I read an artcle once that stated how much they helped. I thought it was only 20% or something like that... (Then again .77G to .92G would be a lot of traction!)
spdkils
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
