i give up
Old Aug 21, 2005 | 05:11 PM
overZealous1's Avatar
overZealous1
Originally Posted by narkotic
Is it possible something is wrong w/ your ECU?
i'm sure it is possible, just not sure how or why. the only code from it is the misfire one. there are separate codes for the cam and crank sensors if they are giving an irratic code. but who knows, i had my cas go out completely and it never set a code. looks like i will be buying an oscilliscope this week though.
Old Aug 21, 2005 | 05:12 PM
overZealous1
problem is everything else datalogs good and consistent from the emanage with no jumpy or irratic signals from the maf or tps.
Old Aug 21, 2005 | 08:13 PM
overZealous1
any more ideas? i know lots of people are having the po300 code.
Old Aug 21, 2005 | 09:52 PM
narkotic's Avatar
narkotic
You never know, maybe something in the Emanage zapped the ECU... That seems to be the only thing you haven't replaced yet. Have any buddies w/ the same year/model z in the area ? heh
Old Aug 21, 2005 | 10:26 PM
overZealous1
well i had an e blue before and it all of a sudden on one start up, it instantly started to blink red and green, leaving the car misfiring very hard with tons of smoke. after trying alot of stuff it still would not work or even be able to communicate with it. i planned on getting the e u anyways so i just got it sooner than i wanted.
putting in the eu made the car run again but getting random misfire codes. i suppose some how the eblue could have sent a signal back to the ecu and hurt it. but it just seems to intermittant for something failed.
i am leaving it up to about 3-4 possiblities now, the stock ecu, the cas, or possibly the new eu. i wasn't getting an output signal from the eu on ch1. want to get a scope to verify though. yet the signal was going into the eu from the ecu. unfortunately the stock ecu can't be bench tested. new ecu is about $700, even jobber price, and i hate to borrow one if i do have a signal going back to the ecu messing it up. i have a line on a used one, but need to check part #.
this is very frustrating as the car has been down 3 months now with 3-4 weeks now just being devoted to fixing this problem. only driven the car about 40 miles so far. each drive ending with driving back to my shop because of misfire.
Old Aug 22, 2005 | 06:33 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
over,
Did you make sure that the airflow correction map is NOT selected or visible on your tree on the left side of the screen?
Call me later today, I was super busy over the weekend, wrapping up some tuning and a customer's car.
Old Aug 22, 2005 | 07:22 AM
overZealous1
Originally Posted by Sharif@Forged
over,
airflow correction map is not selected. actually i am only running on 2 maps right now, just injector and ignition. tried calling, left message, thanks.
Old Aug 22, 2005 | 12:33 PM
dynamic6er's Avatar
dynamic6er
When in the timeline were the 660 injectors installed?
Old Aug 22, 2005 | 10:00 PM
overZealous1
i did the injectors along with the build up of the motor. at one point though i did completely bypass and remove the eu, and put the stock injectors back in and had very similar results to the problem i am having now. i got a smart idea to look at my cam and crank sensors, and saw a little bit of metal slurry on them from the cams and bearings breaking in. wiped it off and all of a sudden it ran almost perfect. so i put it back together completely and it ran good for a little while then went back to having problems. have pulled the sensors again and found no more metal on them though.
i will be recieving a bunch of shielded wire in the next couple days so i plan on doing the both cam and crank signal wires. just one more thing i can eliminate off my list i guess.
keep ideas coming if you can, need more stuff to test. sharif gave me a few ideas today, but mostly on driveability problems having to do with tuning. just need to cure this prob so i can tune, lol. thanks
Old Aug 24, 2005 | 08:23 AM
overZealous1
bump
Old Aug 24, 2005 | 05:50 PM
overZealous1
ok picking up a pc based oscilliscope tomorrow. my last test had me pointing to the emanage not outputting a signal on ch1. but was strong from the ecu. will be able to determine strength of signal now with the scope. it is intermittant though so maybe a hammer will fix the bad connection, lol
Old Aug 24, 2005 | 07:32 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
damn man, sorry to hear about all the trouble you've been having..i don't have anything informative to add, but good luck!
Old Aug 25, 2005 | 06:40 PM
overZealous1
ya it is taking a toll on me, but i tell you one thing, after reading all the shop manuals 4-5 times and toying with all the eu stuff over and over. i feel i have exceptional knowledge of the car, lol. would be better if it just ran good though, hahah.
scored on 80feet of military grade shieled 20gauge wire on ebay for $10 with shipping!! nobody around me would sell it for any less than $1.50 a foot and 1000ft roll minimum. so now going to do the crank and cam signal wires. got a set of ground wires to put on too. doubt this stuff will fix the prob, but will eliminate more possibilities. will finally have time to work on car again sunday.
Old Aug 29, 2005 | 02:46 PM
IceY2K1Max's Avatar
IceY2K1Max
What's this about? You found it caused a problem?
over,
Old Aug 29, 2005 | 07:38 PM
overZealous1
it actually is the airflow output map in the emanage map select parameters you don't want to select. instead use the airflow adjustment map. don't remember why right now, but the airflow output map is not compatible with the Z.
Old Aug 29, 2005 | 10:30 PM
IceY2K1Max's Avatar
IceY2K1Max
Okay...that's not my issue then. I've never selected that map and I've even disconnected the laptop and it's acted the same, ie throwing a CEL for an ignition misfire code.
Old Aug 30, 2005 | 08:22 AM
overZealous1
is it intermittent? does the emanage have a trouble going showing also? how often does it happen? can you hear the misfire or a cylinder being dropped?
  #38
overZealous1
what does it take for it to stop, or does it just stop on it's own?
Old Aug 30, 2005 | 08:59 AM
  #39
IceY2K1Max's Avatar
IceY2K1Max
It doesn't misfire enough to feel at idle, but I haven't drove it around connected yet.
Basically, I watch my OBD scanner and keep clicking on refresh to see what code is pending. It is there most of the time, but every 5-10secs. maybe, it won't be there. However, as soon as I shut off the engine, then re-start, the check engine light comes on.
John@J&S has suggested a few things I need to try this weekend. Basically, run a new ground from the negative battery terminal and install some resistors to ground on the ECU output(EU input). Hopefully, that makes my stock ECU happy.
Thanks for the help.
Old Aug 30, 2005 | 09:30 AM
  #40
overZealous1
maybe i will give it a try too. let me know how it works out.
sales@czp
Sep 23, 2019 03:30 PM
Alexreyes
Sep 30, 2015 11:30 PM
