Need Help: Not Boosting
Old Aug 25, 2005 | 06:49 PM
Barzten1's Avatar
Barzten1
Default Need Help: Not Boosting
A friend of mine helped me change out my plugs and we also replaced the sleeves for my Vortech piping. Plugs went in fine and got everything wrapped up but my boost guage is not showing a vacume and I'm not boosting anymore. Any ideas?
Old Aug 25, 2005 | 06:53 PM
narkotic's Avatar
narkotic
If it's not showing a vacuum nor boost... then your motor is either not running and there are gremlens pushing it, or your boost gauge is broken.
Old Aug 25, 2005 | 07:39 PM
Barzten1's Avatar
Barzten1
Help!
Old Aug 25, 2005 | 07:42 PM
westpak's Avatar
westpak
SFZCC
I agree there is something wrogn with the gage or the hose for the guage is disconnected.
If you mean that the car doesn't build up boost during opration then one of the couplings you replaced is lose.
Old Aug 25, 2005 | 07:44 PM
Barzten1's Avatar
Barzten1
I'm not getting the pssshhhhh from the BOV and I'm almost positive the couplings are more than tight enough. Was waiting for help but I guess I'm gunna go disect it again. Thanks fellas.
Old Aug 25, 2005 | 07:45 PM
Barzten1's Avatar
Barzten1
It was working perfect before we started the project. All components should be working fine.
Old Aug 25, 2005 | 07:52 PM
westpak's Avatar
westpak
SFZCC
I would check the hose and wiring with the pressure sensor.
Recheck couplings.
Are you running the car on the street or just revving it in the driveway?
I am not familiar with the SC but the TT doesn't set the BOV during standstill revs only under load, but I would assume the SC would boost just revving since it is belt driven?
Old Aug 25, 2005 | 08:32 PM
Barzten1's Avatar
Barzten1
I took it for a spin. Getting it jacked up now for reinspection. Thanks again for looking out man.
Old Aug 25, 2005 | 09:36 PM
Barzten1's Avatar
Barzten1
Found the vacuum hose that was not fitted. Really.....thanks guys!
Old Aug 26, 2005 | 05:17 AM
westpak's Avatar
westpak
SFZCC
Good, sometimes it is the simplest solutions.
Old Aug 26, 2005 | 05:32 AM
mcduck's Avatar
mcduck
Yep... first thing I thought was that it was probably a vacuum line you took loose or accidentally pulled loose. Glad you found it.
Old Aug 26, 2005 | 09:43 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I wish all fixes were this easy. Glad its solved!
Old Aug 28, 2005 | 09:44 PM
MY350Z.COM's Avatar
moved
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
