What breaks when boost goes up?
If a FI system is added as the max boost goes from stock to whatever the max is, (24PSI?) what breaks in the engine and needs to be upgraded?
I hear that at 8-9 PSI the stock engine can handle it but going to 15PSI then the piston rods start to bend.
If I build an engine and use better rods, pistons, and head bolts, what else needs to be tweaked? Valves? Cams? Springs?
Tx
Tx
