Ati Limitations?
Originally Posted by jy535
badmonkey, u finetuned the flash by your self with the emanage?........
jy535, I drove from NC to Altered Atmosphere and had my reflash and tune done. I don't think you'll find many people on here that will disagree with having a reflash done on the dyno. You just can't get any better as far as that goes. It was a 4 and a half hour drive for me but it was worth it for the piece of mind. This is all considering you are going to stick w/7lbs and leave it alone.
On the other hand, if you think you are wanting to upgrade I would just send your ECU to whoever and have the timing maps done (stock tune), your rev limiter raised, and the wide open throttle thing done and get your a$$ down here and let Sharif get the EManage Ultimate on it. From what I've read on the forums, it looks like the EU opened up all the doors that were closed in tuning 350's before and Sharif probably has more experience than anyone in tuning Greddy systems on 350's.
One more thing, you should definately invest in a return fuel sytem no matter what.
GOOD LUCK!
GOOD LUCK!
Workshop12
Mar 23, 2020 01:45 PM
