APS TT idle speed
The idle is around 800 rpm, but every 20 or 30 seconds down to 700 or 650 rpm and it turns very unstable,then back to 800.My vacuum before installation was around 20-21 In.Hg, now is around 18.
Originally Posted by al_v
My idle speed is not very stable after the installation of my APS TT kit, some guy have had the same problem?
Accelerator Pedal Released Position/Butterfly Valve Closed Position Learning
James
Originally Posted by James@APS
You will need to follow this procedure below to ensure a stable idle quality after the TT install, this info in on the APS website, at the end of the install instructions, hope this helps.
James
James
I checked every thing ,accelerator Pedal Released Position/Butterfly Valve Closed Position Learning, vacuum leaks ,etc.
James
It's the blow off valve. Any BOV that vents to the atmosphere will need to be tightened down quite a bit, along w/ performing the idle learning procedure. Mine died every time but after tightening the BOV and a week of driving it's back to normal. Sometimes it will dip way down but then come right back up.
You could also raise the idle...
I haven't messed with the BOV.
Once I get the EU wired in, I'll be able to monitor the MAF, and clamp it if there are any irregularities and LOW RPM. (Fixed my brothers idle issues due to turbo blow by... His MAF is before the turbo... Well it wasn't idle issue... I guess his was a stall issue after closing throttle after boost. )
I have an 05 z.
I have an 05 z.
liqalu04
Jan 2, 2022 12:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
