High EGT Temp on Vortech!
Old Sep 13, 2005 | 11:05 AM
Gman2004's Avatar
Gman2004
Originally Posted by g8tor20
Well...I may try and install a Borla TD Exhaust before my Friday Tune. Between the two...I should get my EGT's down a bit even if it means a loss of boost and/or power.
with a better flowing exhaust you might loose boost, but will gain power. esentially the motor will be more efficient.
g8tor20's Avatar
g8tor20
Thanks for the replies UP. I will have them checked. The reason I say this is through a lot of reading on S/C and back pressure. It seems as if they need some amount. Neffster, who had his installed and tuned at the same time, only made 3 whp more (his is MT and i am AT....meaing I actually produced more at the crank) and he has Craford headers, cats, cat back exhaust, plenum, etc.. From my review of dyno sheets, a complete air flow doesn't help that much. It does lessen the boost though. I may be wrong...but that has been my interpretation of this subject.
Old Sep 13, 2005 | 11:08 AM
Badmonkey's Avatar
Badmonkey
I see 10.5 psi at max RPM's. My sig tells my mods. My boost does not drop off at all.
Old Sep 13, 2005 | 11:11 AM
g8tor20's Avatar
g8tor20
UP...here is Neffster agreeing with me on a recent post over on Driver
http://www.g35driver.com/forums/showthread.php?t=66996
Let me put it this way. There are gains...but its minimal and I wasn't planning on spending any more money. But...knowing how hot I am running...its now become worth it and I'm gonna try and do this all before my retune on Friday.
Old Sep 13, 2005 | 11:14 AM
UnderPressure's Avatar
UnderPressure
Your gains will be greater due to the restriction of the exhaust system, NA vs. FI. ANYTHING will be better than what is on the car now.
Good luck w/ the install.
Old Sep 13, 2005 | 11:21 AM
theking's Avatar
theking
Jason, I thought I explained this to you on the phone. Even though your boost may go down according to your gauge you will be flowing more air. Your a/f will lean out slightly and your egt's will go down. You will make more power with the free flowing exhaust. Boost is a difference of potential meaning one side is pressing against the other. When you free up the flow on one side the difference goes down even though the flow is the same if not better. Give me a shout if you have any questions.
Alan
Old Sep 13, 2005 | 11:28 AM
g8tor20's Avatar
g8tor20
Alan. I thought I explained to you over the phone that your technical babble went over my head.
Relax guys. I understand the concepts you talk about....I am just relaying information I have learned through countless Vortech Dyno readings and Vortech posts on both Driver and My350z. Just seems that free-flowing exhausts don't bring the type of gains people intend. Of course I am doing it for a different reason (heat). And Alan...I don't want to get anymore lean as my a/f already tinkers with the 12:1 ratio. Hopefully all will be solved by Friday and I can happliy report good news.......
Old Sep 13, 2005 | 12:24 PM
diegonismo's Avatar
diegonismo
i have defi egt at .05 bar 700 c in low and hi boost not pass 730 c
350Z_Al
Oct 29, 2020 07:44 PM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
SharX59
Sep 27, 2015 09:23 AM
