I can't believe I want more!
It cuts more fuel then possible for combustion... So basically it is a misfire, not a lean condition... No detonation/pri-iggy
Lots of Supra people install it because for high boost applications it can react VERY quickly, and cuts power effectivly without using fuel cuts that cause a lean burn...
RaceLogic Homepage Tech
http://tinyurl.com/9yn6j
Fuel Cut
The idea of cutting fuel to an engine sets alarm bells ringing in engine builders, as they all know of the potential disaster of a high revving race engine running lean. Running in a lean combustion mode will elevate in-cylinder temperatures very rapidly, the denser the air/fuel charge, the more heat the lean burn can generate. Therefore it is vital that a fuel cut system will not cause a lean burn.
The simplest way of preventing a lean burn is to remove more than 50% of the fuel from the pulsed delivery.
Originally Posted by spdkils
I'm also AMAZED that more people arn't clamoring for 3.0 rear ends!!! With high HP numbers our TQ is HUGE!!! Yet VERY few people are putting in taller gears to match the TQ we're making.
I'd buy a 3.0 rear in a heart beat... You'd be able to stay in gear longer, and use more of your TQ instead of having it spin off @ the wheels, or be wasted with time shifting...
Depend on your goals...I think taller gearing would be nice for a street driven car...but personally, the current gearing will allows our cars to run to 185mph (RPM limited), and thats tall enough for me.
Originally Posted by phunk
paul: i think with a large exhaust, a plenum upgrade, and a retune, you could be well up to 600whp even with your 100% stock heads.
Originally Posted by Gman2004
Well I have had my car back for about 3 weeks now and I thought I wouldn't be saying this, but I want more power! My last dyno was 543whp and 490tq at 12.5psi. I think imma have to order me those new wastegates SGP is making and have the boost turned up to 14psi or 15psi.
Originally Posted by xsmallpaulx
the exhaust is already on order, what plenum would you recommend charles?
Originally Posted by nis350ztt
If you email the video to me i'll host it.
http://www.uploadhut.com/upload/324492.mpg
And to think I laughed when a local tuner told me the "supra guys" were running 700, 800whp and were begging him for more HP. How long before more of us Z guys are clamoring for the same?
Originally Posted by Z33Concept
Up the boost to 20 psi Gman and have it tuned on a 93 Octane fuel map.Get sum 1000CC injectors
You would be making close to 750whp at that boost level.
Originally Posted by Sharif@Forged
And have a spare short block ready.
I should be good then.
Upgraded Long Block #3: - Good up to 850 Rwhp
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons .020 over(8.5:1 or 11.5:1)
*Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*JWT Upgraded Cams
*JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
i can see guys getting 800whp and something like a 1.5-2.0 final drive where you can do something like 0-80 in 1st gear then people start wondering why they got a manual in the first place if they hardly ever shift their car.
You won't have to do that. Like I said in an early post, I am looking into a DTA standalone that has traction control, hell I am even considering the Motec. First I have to sell an investment property and see what my end of year bonus is like, cause there are other things I want first. Anyway, if I go full standalone with traction control it won't matter how high I go with whp cause I am going grip like a *****!
MOTEC UNIT 6,000-10k. The best thing about it it can onl be programmed by the orginal owner
