Single Turbo 1/4 Times???
Old Sep 26, 2005 | 05:58 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by D350Z10
Crawford makes the best headers for the Z,i have them and they are amazinggggggg!!!
Best mod i ever bought, they also put out the highest numbers for the Z, i am dynoing my car pretty soon, and will post!
In your sig it says Emanage-Tuned. How can you have a tuned emanage if you havent even dyno'd yet? Im assuming you at least have a wideband and have tuned the A/F on the street. If so you can still mess with timing for optimal gains.
Old Sep 26, 2005 | 06:05 PM
D350Z10's Avatar
D350Z10
The emangage was tuned prior to the header install, my tuner took fuel out. I don;t recall the exact a/f ratio but i do know that the car was running to rich. I have to get re tuned now that i have headers, but i am holding off till the turbo install now! Then I want to do the technosquare flash, then retune the emanage to that! This will take me pry month and a half.
Old Sep 26, 2005 | 06:12 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Curious what were your numbers prior to headers?
Old Sep 26, 2005 | 06:15 PM
D350Z10's Avatar
D350Z10
I had 260 rwhp, and around 240 tq @ 6329rpms.
Old Sep 26, 2005 | 06:17 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Good hp, kinda low on TQ, Im sure the Crawfords took care of that though...
Old Sep 26, 2005 | 06:23 PM
D350Z10's Avatar
D350Z10
Thanks, true about he tq.. kinda weird but thats how Z's are! You gotta invest in a pair of these headers! You will love them.. with your driving you will pry be at 12.5-12.6!!!
Old Sep 26, 2005 | 07:33 PM
taurran's Avatar
taurran
Which one of thsee headers is the driver's side? If it's the one on the left, then there's no way that coudl fit with the kit. If it's the one on the right, then yeah, I might see it fitting.
My DC Sports headers fit, but rubbed, which was hugely annoying, caused an exhaust leak, and raised my engine bay temps considerably. I swapped them out with my stock manifolds and was glad I did so. In the process of the swap, I lost just under 10whp on the top end, but now the car spools much faster and smoother. Before, I was hitting a full 8.5psi at around 3900rpms. Now, I'm getting full boost closer to 3300rpms. While losing some top end power, I think I gained more power accross the power band.
I'm more interested in learning what kind of gains your friend was able to get with a proper tune via the EU, and also what kind of gains the cams gave him. I eventually at least want to go with some kind of engine management, but I'm not so sure about cams as the install is $$$.
Sometimes I forget that there are a LOT of FI 350z owners out there that have never bothered to visit these forums or arent internet savvy enough to do so. It's a shame, because this kind of info is extremely valuable to others who are looking at the same types of mods. Right now we have a few people here who are going to be installing the EU shortly and there's a lot of us waiting on the results of that to determine what we should do in the long run.
Old Sep 26, 2005 | 09:46 PM
ZON's Avatar
ZON
Custom Badass!! That's the first thing that came to mind when I saw this.
Attached Thumbnails Single Turbo 1/4 Times???-st.jpg
Old Sep 27, 2005 | 08:48 AM
D350Z10's Avatar
D350Z10
Good news... I talked to doug today, owner of Crawford, and he said if the Kit uses the stock manifold, the crawford headers should Fit!!!! So they crawford headers can work with the turbonetics kit, along with many other headers!!!!!
Old Sep 27, 2005 | 08:55 AM
MIAPLAYA's Avatar
MIAPLAYA
The key word is could. In real practice thats not the case. The size and position of the primaries on aftermarket headers typcially interfere with the downpipe. Ask taurran he had the same issue with his DC Sports headers.
Old Sep 27, 2005 | 09:00 AM
D350Z10's Avatar
D350Z10
Did you heat wrap you headers? That will control the engine bay temp, and supply padding between the downpipe and headers?
Old Sep 27, 2005 | 11:39 AM
taurran's Avatar
taurran
No. That still wound'nt fix the misalignment issues and exhaust leaks. If anything, the extra diameter from the heat wrap would cause it to fit worse.
I ended up high-temp coating my stock manifolds and swapping them back in. In the process I header wrapped all of the exhaust and turbo piping, which drastically reduced the underhood temps generated by the turbo. As of now, just from popping the hood and feeling the heat after a hard drive, the turbo side of the engine bay isn't noticably warmer than the opposite side. That leads me to believe the header wrap is doing a great job. In the next few weeks, I'm going to be installing my vented hood, with this it should make any engine bay heat issues nonexistant.
As with many mods, running headers that *fit* with this kit will most likely be a tradeoff. Because of the larger diameter piping you will spool later, but should gain power up top. If you're going for all out power on the top end and you aren't getting any vibration or leaks, then I'd say go for it. But, personally, I'd probably rather be in full boost at 3300rpms as opposed to 4000rpms.
Old Sep 27, 2005 | 03:44 PM
dirtroad's Avatar
dirtroad
13.5 @107 w/aps st in 100 degrees at 2200' altitude. 340rwhp on street tires at about 2.2 60'.
Old Sep 27, 2005 | 03:52 PM
D350Z10's Avatar
D350Z10
Its gotta be the altitude, with the aps kit you should be in the high mid 12's to Low low 13's on a bad day! Thats weird. What do you launch at? Do you slip the clutch? Wot shift?
Old Sep 27, 2005 | 06:22 PM
kopo's Avatar
kopo
Here is my aps st times. Best I ran was a 12.931 @ 108.7 with a 2.215 60'. Couldnt launch because im using continetal all season tires @ 33 psi. Times all night were in the 13.0xx area with traps between 108-113mph, and 60' being mostly in the high 2.5xx. With better tires and learning how to drive I think I can get into lower 12s, this was my first time ever at the track so I was pleased with the times.
Old Sep 27, 2005 | 06:26 PM
D350Z10's Avatar
D350Z10
Oh yea you got that easly, best street tires Bf goodrich T/A KD tires extreme performance i pulled a 1.95 60 on the street with these babies!
Old Sep 27, 2005 | 06:37 PM
zman1910's Avatar
zman1910
Hmm if thats the case then those are the tires ill be going with.....any idea if they are better than the Michelin PS2's?
Old Sep 27, 2005 | 11:08 PM
  #38
Bullitproof's Avatar
Bullitproof
if you can find the kd's in your saize, i would go for them. i think they are marginaly better than the ps2's, but not by much. both have a treadwear in the lower 200's, so look at replacing tires often.
Old Sep 28, 2005 | 02:33 AM
  #39
D350Z10's Avatar
D350Z10
The KD are the best dry traction try out there! the size is 275/40/18 245/40/18- 18 in rims!
Old Sep 28, 2005 | 07:32 PM
  #40
MI 35th's Avatar
MI 35th
OGPremierMafia
yes i love my bf goodrich! best tire money can buy even though they are cheaper than most of the competition...
