vortech
Old Sep 28, 2005 | 06:45 AM
blackend's Avatar
blackend
Default vortech
the car having topspeed header+dual exhaust system and test pipes and AAM spacer.so is there will prob with that?cause i want to fix it out of the box without tune it cause we dont have shop to tune it?one thing iam putting 98 octen fuel?
Old Sep 28, 2005 | 08:07 AM
350ZZack's Avatar
350ZZack
what?
Old Sep 28, 2005 | 08:14 AM
taurran's Avatar
taurran
He wants to know if the vortech with the out-of-the-box tune would be safe with those mods. I have no idea, personally.
Old Sep 28, 2005 | 08:21 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
hes from UAE, pardon his english.
no idea if itll work, but my guess would be itd need some tuning.
Old Sep 28, 2005 | 08:49 AM
zachcrosen's Avatar
zachcrosen
I had almost identical mods when I first my Vortech on. I was running VERY lean under WOT and on the dyno, my AUX fuel pump was not kicking in so I went extremely lean at WOT. I wouldnt run the car with these mods without a retune or you could be dropping another 7-8K on rebuilding the motor. If you are going to drop the cash on the kti itself, you need to drop the change on the tune to get it running right IMHO!
Old Sep 28, 2005 | 09:03 AM
blackend's Avatar
blackend
Default what i mean is
what i mean is the same as taurran said..
Old Sep 28, 2005 | 10:01 AM
jpc350z's Avatar
jpc350z
The kit comes with relatively rich fuel map's. These are based on a stock 350z. With the air breathing mod's you indicate are on the car it very likely will run lean.How lean? It is hard to guesstimate and a dyno tune would be the safe way to go..Hope this helps
Old Sep 28, 2005 | 11:30 AM
booger's Avatar
booger
I dont know if they have changed the tune in the piggyback . But with the same mods for better breathing . I was real rich in the upper rpm range . But as some one else said...put it on a dyno to find out
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
