Procharger Question
Old May 1, 2006 | 03:54 PM
trefling's Avatar
trefling
I live in Kansas City very close to ATI, I know for sure that they never said the AXIS car has 500 at the wheels. There is lots of mods to the kit that need to be done in order to have 500rwhp
Old May 1, 2006 | 04:01 PM
leemik's Avatar
leemik
when they dynoed the Axis car in sport compact ("The One" remember that issue?) it got 341.2 WHP
Old May 1, 2006 | 05:53 PM
Quamen's Avatar
Quamen
I am not talking about the yellow Z that is Chen's personal car. I am talking about their race car with a built motor, cage, stripped interior etc. When I spoke directly with ATI they said that Axis was at 500hp.
Old May 1, 2006 | 06:54 PM
ABL 2 FLY's Avatar
ABL 2 FLY
It is true that axis has a 500whp Z. We recently dynoed mine in at 488whp. With a good tune on the Utec we should be at 500whp...
Nothing is impossible
Old May 2, 2006 | 08:40 AM
lilmixedazn's Avatar
lilmixedazn
Default procharger
hey ok.. i'm a girl ok, and i have a procharger in my 350z, ((ex-bf put it in)) but it's been about a year, i've changed the superchager oil, changed the belts, done all the right maintenance and for some reason my car is squealing!!! the mechanics said it's cause the supercharger is throwing my "harmonic balance off" and the pullies are griding for some reason i feel like he's trying to rip me off, when the car is warm then it doesn't squel, but if i have the ac on when i start the car it's almost a definate that it will, but if i shut it off then turn on the car, it'll be ok.... but if anyone else has heard about this problem or know something let me know PM, cause i'm really lost... thank ahead of time
Old May 2, 2006 | 09:03 AM
leemik's Avatar
leemik
your belts are loose.. it happens to me a lot in the winter time.. just have someone tighten them...not the supercharger belts, I'm talking about the power steering, alternator/AC.. drive type belts..
--mike
Old May 2, 2006 | 11:03 PM
Ep3's Avatar
Ep3
its ok bro mike would have helped out if you said you were a guy 2
Old May 9, 2006 | 06:20 AM
trefling's Avatar
trefling
Get her tuned yet ? I did some more testing today...Im stuck at 13 to 13.4psi from 6000rpm to 6800rpm . Bigger IC and pipe got me to 13psi a littler sooner and cooler intake temps , But no more boost when the belt starts to slip . May try the smaller pulley to get it even sooner and call it a day , till Vortech comes up with a all cog belt set up
Most of the work has been done and Shariff has done some tuning as well. We put a huge intercooler on the front, unfortunantly we did loose 3-4psi in the process but the intake temps are very cool. The 50/50 mix of water/methanol makes the intake charge even more dense. At this point Shariff is pushing the boundaries of tuning because the combination of injection and the big intercooler has allowed virtually zero, zip detonation . I think he has gotten about 450 at the wheels so far and we'll see how much further things can be pushed. I'm using the meth/water to tune with, not just as a safty backup considering we are only getting 12psi of boost. We are going to hook the nitrous back up and either use a 50 or 75 wet shot. With 8.5:1 compression pistons I don't think it should be a major problem especially with the meth/water injection.
For those of you who have considered using injection there are huge benefits. Drastically cooler intake temps, octain boosting effects and cooling due to methanol. And water quenches detonation better than just about anything but the combo of meth/water at a 50/50 ration seems to work best.
You can lean out the mixture slightly and the injection systems light goes off if there is any kind of blockage or flow problems. I'm using the progressive boost controller with www.coolingmist.com and it does everything they claim it to do.
Old May 9, 2006 | 12:55 PM
booger's Avatar
booger
WOW..Im suprised you lost that much psi . But after thinking about it , I think I understand why . You will end up with a very safe set up , with very good power !!!!!
Old May 9, 2006 | 03:08 PM
trefling's Avatar
trefling
I'll take some pics when I get it back with the front bumper off, man this intercooler is huge! It's bigger than the greddy unit. All that air volume get compressed and harder to push but the positive aspect is that the intake temps are cooler than say with a smaller fmic. It will be tuned to 550-575 at the wheels with nos and we'll call it good. I was hoping for 500rwhp but 450 apprears to be all I can get with the 12psi of boost I have to work with. The huge fmic and all that volume plus the low compression pistons make allot of work for the blower. With a smaller intercooler and a little higher compression ration 500 would be achievable I believe, but I don't think I'm going to end up seeing it without nos, which of course I love so it all ok
Old May 9, 2006 | 05:44 PM
ABL 2 FLY's Avatar
ABL 2 FLY
I got my car back awhile ago with 500whp.. But we keep breaking belts. The car is set at 14psi but peaks at 15.5. Does anyone know where to get stronger belts or a new setup
Old May 10, 2006 | 05:34 AM
trefling's Avatar
trefling
CPRacing & Sharif have witnessed first hand that the procharger (brokecharger) actually flexes forward during high rpm's with the big 44 tooth cog drive pulley. Someone needs to find a way to brace the blower bracket to the engine because they said they could literally feel the blower moving forward. The aluminum bracket works fine at low boost but flexes and moves when spun much faster. ATI obviously underengineered the the aluminm bracket because it simply is not strong enough. I'm sure someone will figure something out
Anderson Distributing
Greensboro NC
Bluebell St.
Procharger belts
336-379-0400
Big Belt PowerGrip GT2
8808mgt30 1464MC $37.65 (large belt)
5608mgt30 $27.67 (small one)
This is the only way to go for belts, no won't find them less expensive anywhere else. But cheap belts is not the solution, we have to find a way to keep it from flexing under high load.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
