Koyo radiator install...questions???
Originally Posted by Gman2004
Not to put down the koyo, but those of you that are looking to replace your radiator check out the PE unit. It is a direct drop in and no modification needed unless you own a G. Even then it is just relocating the top mounting brackets. It is a little bit more expensive, but doesn't have to be jigga'd in, like some have had to do with the koyo. I got mine from Sharif@Forged.
^^^totally correct...but not everyone is a high roller like you, George!
^^^ I mentioned the PE to Todd, but since he is doing the install himself, he's going to say a some money going with Koyo. Also, the Koyo requires minor mods to fit the 350Z, but lots of mods to fit the G35.
Originally Posted by 350zDCalb
the modding is the fun part...if it just dropped right in, what fun would that be? come on now
builtZmotors
builtZmotors
Originally Posted by Sharif@Forged
Todd, your Koyo is on the way!
hey, i saw your article in turbo mag..very cool...
Originally Posted by G3po
The way the FMIC plumbing is run on the APS TT (pasenger side), I'm pretty sure you'd still have to "jigga" the PE radiator and Fans as well, especially on a G.
I would suggest the 36mm with the APS kit, to avoid the potential for interference. Some people have installed the 56mm and they claimed they dropped in...others have had some fitment issues.
Nothing fits the G35 perfectly.
Well, they fit, but you need to make some brackets for the top rad mounts...easy to do...but not a drop-in affair.
Interesting... why is there a conflict on the 56mm? Some say it fits, some say it doesn't? What's true? Much difference between the 56 and 36?
What is the stock radiator size in milimeters?
On the dyno, I never saw a massive issue with even the factory OEM cooling capabilities, so I figured that 36mm (nearly twice as thick as stock, would be more than sufficient.
Any competent shop can make any of the rads work with the TT kits. It might just take some creativity, and a little custom work. But to simplify things, we usually suggest the 36mm Koyo. Hope that helps.
Originally Posted by ZU L8R
Yes, the thicker version Koyo will NOT work with a Vortech. I have a cut to hell fan shroud to prove it. Still didn't work.
http://store.summitracing.com/partde...part=FLX%2D220
Originally Posted by NETSHARK
Why don`t you try Flex A Lite Low Profile Fans ? am sure they will work with your setup, you just need to make a modification for the lower mounts.
