Starting car for the first time after new cams?
Old Oct 15, 2005 | 03:45 PM
G352NV's Avatar
G352NV
Default Starting car for the first time after new cams?
Anything I need to do? I was told I had to prime them, is this true?
Old Oct 15, 2005 | 04:16 PM
g356gear's Avatar
g356gear
As long as they were installed with cam lube they should be fine until oil pressure comes up.
Old Oct 15, 2005 | 04:55 PM
phunk's Avatar
phunk
CJ Motorsports
did you check your valve lash after installation?
if you prelubed them well, it should be ok to just start the engine... but it certainly wouldnt hurt to just prime the engine with oil pressure just to be safe. to do so you can unplug the fuel injector harness on the back of the engine and crank it until the oil pressure light turns off.
Old Oct 15, 2005 | 08:47 PM
G352NV's Avatar
G352NV
Thanks! Will do!
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
