White smoke coming out of driver's side tail pipe
Old Oct 23, 2005 | 07:08 PM
g356gear's Avatar
g356gear
Originally Posted by Gman2004
How many hours would it take to replace a head gasket? What should I expect to pay to have a head gasket replaced?
Same as doing a cam swap....probably 12-14 hrs with the motor in the car.
Old Oct 23, 2005 | 07:19 PM
Gman2004's Avatar
Gman2004
Do you have access to retorque the bolts while swaping a gasket?
Old Oct 23, 2005 | 07:27 PM
g356gear's Avatar
g356gear
If I remember correctly the head bolts are underneath the camshafts.....so the cams would have to come out to check the head bolt torques anyhow. You are looking at maybe only an extra hour labour to do the gasket as opposed to just checking the headbolts.
Old Oct 23, 2005 | 07:46 PM
JETPILOT's Avatar
JETPILOT
With that kind of boost wouldn't it be silly not to O-ring the head and block?
Old Oct 23, 2005 | 08:25 PM
g356gear's Avatar
g356gear
I have not seen any vq builders yet who do it....not even AEBS.
Old Oct 23, 2005 | 08:27 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
correct, cams need to be removed to access the head bolts
JETPILOT's Avatar
JETPILOT
I don't know much about the VQ. Someone has to be the first to do it. I guess as demand grows someone will do it eventually.
Old Oct 23, 2005 | 09:00 PM
g356gear's Avatar
g356gear
This is actually the first headgasket I have seen....if that is indeed the problem.
Old Oct 24, 2005 | 06:51 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
O-ringing the stock open deck wouldnt provide any benifit, IMHO. Sleeving is a better option.
Old Oct 24, 2005 | 05:54 PM
t32gzz's Avatar
t32gzz
Keep us posted Jorge. I hope it turns out to be a turbo seal. It is a cheaper way out. Don't sell the car!
Old Oct 26, 2005 | 06:49 AM
Gman2004's Avatar
Gman2004
ok the chit is fuked up down here. our infastructure is pretty damaged. I am at work so I am able to get on the net. anyway, as soon as the power comes back i will take the car to the shop to get a compression/leak down test and pressure test the radiator. if it is anything major the car is going to be shipped to SGP since they built the motor and I bought the warranty. I don't know exactly what the warranty cover, but if there is major damage I hope it falls under warranty.
Old Oct 26, 2005 | 03:52 PM
roncfpz's Avatar
roncfpz
Jorge, sorry to hear about your engine problems. I feel for ya. Hope it's back up and running soon and covered under warranty. Good luck.......don't sell it!
Ron
Old Oct 26, 2005 | 04:40 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Ron
are you joking? how in the world would the factory warranty cover a built motor?
Old Oct 26, 2005 | 04:43 PM
t32gzz's Avatar
t32gzz
Not the factory warranty.. the SGP warranty.
Old Oct 26, 2005 | 05:16 PM
roncfpz's Avatar
roncfpz
^^^ what he said.
Old Oct 26, 2005 | 05:22 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
oh, my bad...sorry .,.yah, if something internally is confirmed, then hopefully they will cover it!
Chris350z03
Oct 8, 2023 07:19 PM
May 12, 2016 07:42 PM
Vigman
Nov 17, 2015 04:34 AM
lolsupfoo
Sep 9, 2015 12:57 PM
